s10 blazer sas
Old Sep 17, 2018 | 08:18 PM
mckinstryj's Avatar
mckinstryj is on a distinguished road
Default s10 blazer sas
im wanting to get a s10 blazer and sas it, its gonna be for the trails only, ill drive it on road tho to the trails, i planned on running a dana 44 front and like ford 9" rear and run 35s and i guess try to find some dodge dakota leafs from like lkq, so i just gotta find any dana hp 44 thats around 60" wms to wms? or do i need to run a certain dana hp 44?
Old Sep 17, 2018 | 08:28 PM
Narrow-track Wagoneer axles are pretty popular. They're widely available, relatively cheap, and pretty close to the right width, though I don't know exactly how wide off the top of my head.
Old Sep 17, 2018 | 08:47 PM
mckinstryj's Avatar
i can't find any wagoneer axles, i found no dana 44s on craigslist, i only found them on facebook market place, i found a hp dana 44 on there that came from a from a 68 f100 for $250 but i don't know if that'll work or not, and idk what gears i should run
Old Sep 17, 2018 | 08:56 PM
You might have to keep an eye out for a bit. They're out there. Make sure you get one with the differential on the proper side, or you'll have to change the transfer case. Scout axles will also work, but they're much harder to find than the Waggy ones.
I don't know where you're located, but I got one once from a Jeep-only junkyard near Sacramento (J&W Jeep). They have anything you could need.
As far as gears go, 4.56 or 4.88 would probably be pretty good all-around with 35s and an overdrive transmission.
Old Sep 17, 2018 | 09:20 PM
mckinstryj's Avatar
okay sounds good
Old Sep 19, 2018 | 08:36 PM
mckinstryj's Avatar
what year dodge dakota should i get leaf springs from? is there any other springs i can use? besides rancho, what length springs should i use?
thanks
Old Sep 19, 2018 | 08:47 PM
I think any second generation Dakota rear springs will work. I'm running full-size Chevy lift springs, front and rear (47" front, 52" rear) with one front leaf removed and the bottom overload leaf removed from the rear.
Old Sep 19, 2018 | 09:32 PM
mckinstryj's Avatar
okay so should i run the rear dakota springs for my front and rear or will i need different length springs front and rear?
thanks
Old Sep 19, 2018 | 10:30 PM
Yup, run those on the front. I think the pin offset is too much for the rear unless you want to stretch your wheelbase. The stock springs will work fine in the rear if you put them over the axle and keep the front height reasonable. Or you can use 52" full-size Chevy springs, which I believe will move the rear axle back one or two inches.
4x4guy
Lifting Tech
26
Jun 17, 2013 03:07 PM
greenslug
20
Jun 5, 2013 06:13 PM
dimone545
Mar 4, 2012 07:31 PM
Chris1600
Dec 14, 2011 09:43 PM
ericthughes
Apr 24, 2010 09:24 AM
