1999 blazer, dies if not givin gas
Old Dec 5, 2010 | 05:04 PM
badbrad2000's Avatar
badbrad2000 is on a distinguished road
Default 1999 blazer, dies if not givin gas
Whats goin on guys, i bought this thing at an auction and its a terd. It starts if you give it gas and runs 100% perfectly fine. if you let off, it dies. It is like this in park, or while your driving or in neutral. No check engine light, no misfire, puuuurrrsss like a kitten if your just steadily crusin. ANY IDEAS ???
Old Dec 5, 2010 | 05:11 PM
This could be caused by a leaking EGR valve which is easy enough to pull, clean, and reinstall with the screened gaskets that are available. Follow the EGR Valve Cleaning thread.
There also could be a fuel pressure issue, whether its lack of pressure (doesn't quite match for your symptoms) or a leak in the system under the plenum (somewhat matches). Run a fuel pressure test to make sure everything is working properly
Old Dec 6, 2010 | 04:22 PM
thanks a bunch man, i was told to check the fuel pressure. but definitely gunna clean and mess with that egr. thanks again for the info
robinann
Jun 9, 2015 06:58 PM
Jetpack_Ahoy
Aug 16, 2012 09:15 PM
dcshoes1
Jul 21, 2009 01:48 PM
Poligono
Nov 3, 2008 06:01 PM
jginnc
Jan 18, 2007 07:35 PM
