94 Jimmy won’t shift out of 1st..
Old May 31, 2019 | 06:27 PM
jwalls91's Avatar
jwalls91 is on a distinguished road
Does anyone know where this DRAC module is located? I’ve seen 2 locations on google. Behind the glovebox and under steering column but I’ve looked in both areas and I’m not seeing it
Old Jun 1, 2019 | 08:33 AM
Transman304's Avatar
For the W and Z vin#s most times on right side around glove box area may even be found under kick panel on right side. The size of a pack of cigarettes. 4 wires.
Old Jun 4, 2019 | 08:57 AM
jwalls91's Avatar
The jimmy RUNS AND SHIFTS!! It fixed the problem. The guy that sold it to me must have replaced the vss buffer and forgot to hook it up correctly cuz when I found it I took out the two screws holding it to the ecm bracket and it fell out completely. No harnesses attached. I looked at it and it looked brand new. So I traced the harnesses for it. Plugged them in, reattached those screws to hold it in place and everything is working now.. Thank you all for the help. I really appreciate it
Old Jun 4, 2019 | 07:54 PM
Good job! Glad it worked out for you.
Brad
Old Sep 25, 2023 | 03:19 PM
jeep's Avatar
jeep is on a distinguished road
where exactly is it located and how you get to it? Thanks
Old Sep 25, 2023 | 04:34 PM
jwalls91's Avatar
The DRAC module was behind the glove box, riveted to the ecm. There is a small wiring harness attached to it.
Old Sep 25, 2023 | 08:49 PM
jeep's Avatar
I have a 1994 jimmy the plastic looks it's the whole dash needs to come off
Old Sep 26, 2023 | 02:11 AM
jwalls91's Avatar
I also have a 94 Jimmy. Mine was sitting just below the heater core, probably would be the easiest to access from below the dash where the plastic sits but it sits just behind that glovebox. Is your Jimmy doing the same thing mine was? No shift? No speedometer or odometer.?
Old Sep 26, 2023 | 07:12 AM
jeep's Avatar
My odometer works abs light on and no shifting. Do you know of a video of the plastic being removed. I dropped the panel under glove box and saw the wires going to computer.but accessing it a different story.
Old Aug 24, 2024 | 09:14 PM
Diesel's Avatar
Diesel is on a distinguished road
Default 94 gmc jimmy drives but wont ahift into 3rd
Hey my ignition went out i bypassed it and got a new starter now it wont shift into 3rd....been reading the thread could it b my ignition causing it or do i need 2 follow what was said on the thread
K.13
May 10, 2014 09:23 PM
ptg327
Feb 27, 2012 03:15 PM
mntmotor
Dec 28, 2010 12:03 PM
jadossgmc
Nov 7, 2010 07:51 PM
lpaz
Jun 5, 2008 12:36 AM
