Automatic to Manual Swap
Old Nov 28, 2009 | 07:31 PM
old skool luvr's Avatar
Default Automatic to Manual Swap
Originally Posted by swartlkk
Yep. That '88 will have the old 700R4 while the '93 was the first year for the 4L60E. The 700R4 is manual control while the 4L60E is electronic. They will not interchange without doing some ECU work so it forgets about the transmission.
not to jack this guys thread Kyle-since everyone seems to think i do-but i was wondering what all would be involved for say swapping from an auto to stick?
do you want me to post a new thread for this question, or will you answer it here? much appreciated either way brother.
Old Nov 28, 2009 | 09:06 PM
Yeah, best to do it in a new thread (don't worry, I made it happen).
As far as swapping auto to manual, I am assuming that you are talking about your 98. If so, the easiest thing to do would be to have the PCM reprogrammed with the manual trans programming. A good tuner should be able to do this.
Old Nov 28, 2009 | 10:18 PM
first, thanks for just moving my question to a new thread. figured it was gonna go this way, being to far seperated from the OP that i put it under. that, and it probably would've jacked his thread.
i figured it would just need to be flashed with the different trans info. and i can probably guess it should be for that era of truck, since programming can switch (for the most minor stuff) from year to year.
that's the problem with finding old stashes, you can't leave well enough alone.
thanks again for confirming my thoughts Kyle, good job as always!
SoullessNihilist
Aug 11, 2011 01:58 PM
garciamode
Aug 14, 2010 11:05 PM
trhull
Sep 6, 2009 10:49 PM
dew88
Jul 8, 2009 07:35 PM
p_j_robertson
Jul 5, 2006 06:17 AM
