bye bye motor
Old Jun 7, 2009 | 02:33 PM
john96blazerLT's Avatar
john96blazerLT is on a distinguished road
Default bye bye motor
so i was driving on the hiway and i heard a knocking from the motor and it was not the kind that comes from the valves and within 5 seconds the noise got verry loud then the motor froze and when i stoped and looked under the truck thear was oil leaking out and if i tried to start the truck i could heat the starter trying to move but it could turn the motor, and when i got home i found a pice of the motor on the flat bed truck,
so with that said, where can i find a new moter or is it cheaper to have a mecanic fix it (1996 blazer lt awd 4.3 vortec)and does anybody have any ida as to what could have went wrong
thanks
john d
Old Jun 7, 2009 | 02:40 PM
oisinirish's Avatar
Probably cheaper to have crate motor installed if you don't want to rebuild it yourself.
As to what went wrong...can you tell where the oil was leaking from? What "part of the motor" did you find?
Old Jun 7, 2009 | 03:13 PM
i looked at the motor and i found a hole 1 in by 1 in and the gm part number that has the hole in it is 10207711, and the hole is on thr front drivers side, just on the side
Old Jun 7, 2009 | 03:21 PM
oisinirish's Avatar
The hole is in the engine block? If that's the case you're gonna have to get a new block. I would guess you threw a rod.
Old Jun 8, 2009 | 08:50 AM
Colby 04's Avatar
Colby 04 is on a distinguished road
pics??
Old Jun 8, 2009 | 09:09 AM
oktain's Avatar
I tend to agree, my buddy's ford probe did the same thing, a really loud knock and then the engine just konked out. He pulled over and there was an oil slick behind him, turns out a connecting rod snapped and punched a hole through the block.
Now you have an excuse to put a V8 in! lol
Old Jun 8, 2009 | 09:36 AM
96chevblazer's Avatar
Yea go with a create engine, or find a cheap blazer with a bad tranny and buy it, then pull the motor and sell the rest of it for scrap.
richphotos
Apr 21, 2012 08:08 PM
01BlackBeauty
May 2, 2011 01:11 PM
FoxTrota
Mar 11, 2011 08:51 PM
TheNewKid
Sep 13, 2010 09:52 PM
kiwiblazer
Aug 28, 2008 04:15 PM
