Hard time starting; need advice!!
Old Feb 19, 2022 | 01:02 AM
thekid.alex's Avatar
thekid.alex is on a distinguished road
Default Hard time starting; need advice!!
Hey everyone. So my blazer recently started having trouble starting up. It takes a solid 4-5 seconds of cranking to get it running. I did a fuel pressure test and primed it, i immediately noticed that the pressure reached 60 psi but started to drop pretty quickly. I'm wondering if it's time to change my fuel pump. I have 150k miles and i believe i still have the factory pump. My question is; is it really the fuel pump or is it a different issue? I'm tight on money right now because i'm a student, so i want to try and get it right the first time. Thanks!
Old Feb 19, 2022 | 09:11 AM
GeorgeLG's Avatar
What year is your truck? The fuel pressure test in the second gen sticky shows you how to separate fuel pump issues from the rest of the fuel circuit when you fail the leakdown test.
George
Old Feb 19, 2022 | 10:26 AM
George
It's a 2001 4wd 4d.
Old Feb 19, 2022 | 11:09 AM
GeorgeLG's Avatar
Then the complete fuel pressure test is your next step
George
Old Feb 19, 2022 | 11:22 AM
George
I do apologize for the inconvenience but could you explain to me the process of doing the complete fuel pressure test? I did do a pressure test and it doesn't hold pressure after I prime it. It goes up to 60 PSI and then immediately starts dropping. I'm also unaware of what a sticky is and where to find it, im quite new to the forum so my apologies.
Old Feb 19, 2022 | 11:56 AM
GeorgeLG's Avatar
No apologies needed, we are here to help you fix your truck.
Here is the “sticky”:
https://blazerforum.com/forum/2nd-ge...eakdown-88305/
The idea is to first see if you hold proper pressure at the schrader after key on. We alsready know that you have failed that test so now the question is where is the problem. You go next to the fuel filter and retest. That will tell you if your problem is in the fuel tank or up at the plenum.
I am the proper diagnosis and targeted fix guy. There are others that like to pick parts to replace on a best guess basis but that’s not my thing.Half the time it’s not even parts but wiring or connectors. I helped another member here recently that replaced his fuel pump which is a nasty job and had the same problem afterwards. It turned out to be a wire from the relay to the pump. Nice guy, easy to work with but it’s a shame that we didn’t avoid the unnecessary part replacement with trynostics first.
George
Lgarretto
Oct 24, 2021 11:57 PM
sportsdaddy11
Nov 24, 2018 12:54 PM
Bobcat13
Sep 13, 2013 09:36 AM
swanman35
Mar 15, 2013 01:17 PM
BT03mach1
Dec 12, 2007 12:44 PM
