TRANNY HELP
Old Apr 21, 2007 | 09:04 AM
sdw25's Avatar
sdw25 is an unknown quantity at this point
Default TRANNY HELP
I HOPE SOMEONE CAN HELP ME MY TRANNY IS SLOW TO SHIFT FROM 1ST TO 2ND I HAVE TO LET OF THE GAS PEDAL FOR IT TO CHANGE THEN IT DOES FINE AFTER THAT ALSO MY SERVICE ENGINE SOON LIGHT HAS NOW CAME ON I CHANGED THE FILTER AND TRANS FLUID ABOUT 2 WEEKS AGO
Old Apr 23, 2007 | 12:11 AM
Hanr3's Avatar
Default RE: TRANNY HELP
Couple of things.
Did you make sure you pulled out the old filter gasket before you put the new one in?
Did you top off the fluid level? To check tranny fluid drive the truck for 20 minutes, park on flat level ground, leave the engine running and check the fluid level. It takes 1 pint (1 quarter of a quart) from the bottom of the cross hatch on the tranny dip stick to the top of the cross hatch. Make sure the tranny is full when warmed up. After you add fluid, repeat test.
Old Apr 23, 2007 | 08:31 AM
sdw25's Avatar
I DID CHECK THE FLUID AND CHANGE THE FILTER GASKET EVERY THING LOOKS NORMAL AS FAR AS THE FLUID LEVEL COULD IT BE A SENSOR OR SOMETHING
Old Apr 24, 2007 | 12:46 AM
Hanr3's Avatar
Did you use gasket sealer on teh tranny pan gasket?
If not, it could be a host of things.
In order of likeliness.
T.V. Cable- what year was your truck again? Nevermind, '98 didn't have a tv cable.
Governor- you got a piece of dirt in it.
Trottle lever & bracket assembly
valve body
oil pump assembly or case.
Old Apr 24, 2007 | 09:24 PM
sdw25's Avatar
I DID'NT USE ANY TYPE OF GASKET SEALER I WILL TRY SOME OF THE THINGS YOU SUGGESTED THANKS IN ADVANCE
Old Apr 25, 2007 | 01:27 AM
Hanr3's Avatar
By the way, what was the code?
Not all trany issues are due to the tranny. Poor engine performance can show up in poor tranny performance due to the way the puter controls torque.
ski.dive
Feb 7, 2014 05:18 AM
twintrades123
Sep 11, 2006 12:26 AM
Zack98Blazin
Aug 30, 2006 05:45 PM
wildcatxcr8
Jun 23, 2006 09:36 PM
swartzy
Apr 28, 2006 10:32 PM
