Differential service
Old Sep 6, 2020 | 05:58 PM
waltbiller's Avatar
waltbiller is on a distinguished road
Default Differential service
This weekend I serviced the rear axle, changed oil, installed new cover and bolts. As careful as possible tried to remove filler plug. No luck. Tried extractors, stripped square wrench hole round and finally drilled plug to 1/2 inch, put in a rubber plug off a Jeep. Filled two quarts with new plunger pump didn't spll a drop. There was about two pints of grungy fluid in there at onset drained and scoured around gears with a telescopic magnet. Probably first time oil was changed in 216,000 miles. Gears looked good after all that. Sometimes it's the little victories. Next guy can torch out the remains of the plug. Next stop front diff.
Old Sep 16, 2020 | 12:10 AM
go chevy's Avatar
You said it! Little victories lead 2 winning the war lol... I 2 am going 2 change the rear axle oil/fluid this weekend along with the front diff fluid
Old Sep 16, 2020 | 11:49 AM
waltbiller's Avatar
Good luck! I bought a plunger oil transfer thing kept the mess to a miniumum. Front diff required it on my Blazer.
Old Sep 26, 2020 | 04:37 AM
go chevy's Avatar
What year is your Blazer? I have a 98...
Old Sep 26, 2020 | 08:46 AM
waltbiller's Avatar
We have a very early 1995 4wd 4door.
Old Sep 26, 2020 | 08:59 AM
Walleye Hunter's Avatar
Walleye Hunter will become famous soon enough
I use vinyl hose connected to the tip on my oil bottle to fill rears and gear boxes with fill holes in the side. Works pretty good for cheap.
Old Sep 29, 2020 | 10:59 PM
go chevy's Avatar
I agree, I picked a hand pump thing that tightens onto the bottle of gear oil and it pumps it right into whatever you want pretty much... I think it cost me around $9 or $10 bucks at Auto Zone.
Old Sep 30, 2020 | 08:04 AM
I go through enough gear oil that it makes sense for me to have a couple of these. They make it super easy.
Old Oct 1, 2020 | 12:08 AM
go chevy's Avatar
Wow, you aren't kidding, a 5 gallon bucket... Nice little set up there.
p.o.s.blazer420
Aug 28, 2012 11:42 AM
blazinloud
Aug 24, 2010 10:06 PM
mrgreazm0nkey
Jul 31, 2010 09:30 AM
greenjimmy
25
Jan 5, 2009 11:12 PM
salvy
Sep 18, 2008 02:23 PM
