key fob
Old Mar 26, 2009 | 12:48 PM
I should have said Tech2 option for the 98+ as this was when they put the BCM in. I do not know how or if it can be programmed on the 96-97.
I have read some stuff that seems to suggest that if you hold the lock button for at least 4 seconds, press & hold the unlock button, and then release the lock button, that it may enable/disable this function, but I am unsure of the application. It is something that is easily tried.
Old Mar 26, 2009 | 02:41 PM
acfiero's Avatar
acfiero is an unknown quantity at this point
no luck, but thanks
Old Mar 29, 2010 | 03:01 AM
cooper232's Avatar
cooper232 is on a distinguished road
i looked at the receiver on mine and the fcc id is ABO 0116T.
when i search on ebay for this i found five results.
but they say pontiac and buick. i understand they are GM vehicles as well but just wondering if these are going to work with my blazer. thanks.
Old Mar 29, 2010 | 08:58 AM
Unlimitedsp's Avatar
Originally Posted by acfiero
oh one more thing. when i lock it with the remote should the horn blow or lights flash or something? mines silent. is there a way to program that?
My 97 dosent do it either. I think they are not programmed to.
Old Mar 29, 2010 | 12:22 PM
The FCC ID on the receiver should end with an R.
Old Mar 29, 2010 | 04:54 PM
Bretta78's Avatar
Bretta78 is on a distinguished road
Where would one find the reciever to get the FCC ID? Total n00b, so pics would be handy :-)
Old Mar 29, 2010 | 06:19 PM
Depends on what you are driving. Most RKE modules are under the driver side dash near the DLC (data link connector).
Old Mar 30, 2010 | 03:48 AM
cooper232's Avatar
ok so i meant to put abo0116r.... i am sure you knew what i meant.
so if i buy a fob that says abo0116t it should work, right?
Old Mar 30, 2010 | 07:37 AM
I just wanted to be sure. Yes, so long as you match the FCC ID from the receiver to that of the transmitter, you should be set.
changeme20
Oct 24, 2020 02:12 AM
davedidit
Jan 1, 2011 07:54 PM
Trip..
Nov 16, 2010 02:27 PM
el8232
Oct 22, 2010 11:52 AM
ray bright
Mar 2, 2009 09:56 AM
