Pulling out my hair anyone have a O ring diagrams for lines to the radiator 02 blazer
Old Dec 22, 2022 | 07:20 AM
justblaze83's Avatar
justblaze83 is on a distinguished road
Default Pulling out my hair anyone have a O ring diagrams for lines to the radiator 02 blazer
So did a radiator swap didn’t look at the inside of the fittings on the old one like an idiot. For things like o rings or metal seals…
So when I dropped in the new rad I screwed in the oil fittings vs utilizing the quick clips. And when I put the fittings in, I got a bad leak on the upper pass side line when the trucks running.
Can somebody please me tell if this fitting is supposed to have a rubber o ring in the inside and also on the outer end??
Didn’t seem like an o ring would stay on here
Old Dec 22, 2022 | 08:00 AM
Knuckle Dragger's Avatar
Knuckle Dragger is on a distinguished road
No, that is not supposed to use an o-ring, it seals on the flare. I see some minor burrs on your fitting that may be causing an issue. Are you getting an oil leak or a coolant leak? Inside the radiator there is a seal to the fitting bung. I have seen those leak.
Old Dec 22, 2022 | 08:19 AM
It’s funny you say that it was leaking out from the line into the nut. And there was also a mess of antifreeze in the area too on a new rad.
I didn’t run it too long to see the coolant leak source and where it’s coming from due to the trans oil flowing out.
I believe I need a dorman 800605 for that fitting. Judging from what you’re saying maybe this will fix both of my issues. I suspected maybe the rad cracked during shipping.
Old Dec 22, 2022 | 08:28 AM
That should be a replacement for the fitting you have. See if you can snug up the big nut holding the fitting in the radiator, don't go nuts though. We ran into a lot of the aftermarket radiators that had issues there. So many the beam counters only allow us to buy the GM or Delco stuff.
Old Dec 22, 2022 | 03:13 PM
Ended up resolving it by replacing the fitting with dorman 800605 and carefully putting the hose into the fitting then popping in the clip.
Found a nice divit in the sealing area of the old one after all.
christine_208
53
Jul 7, 2022 12:22 AM
christine_208
Feb 24, 2019 08:21 PM
jaatecart
Dec 20, 2017 09:42 AM
matt9589
Feb 7, 2013 02:23 AM
oem95blazer
Jul 19, 2009 06:38 PM
