Somone freakin shoot me (or come replace my fuel pump for me) either or
Old Nov 4, 2011 | 01:15 PM
gatorboy44's Avatar
gatorboy44 is on a distinguished road
I feel ya man, my trans and fuel pump went out within a couple days of each other..
Old Nov 4, 2011 | 04:57 PM
Mike98Blazer's Avatar
WELLLLLL the stealership was wrong, it wasn't a removable one. Here's how i fixed it once i had thoroughly destroyed it. I got one of the removeable type vent valves...it's too small to lock into the hole but JUST big enough not to fall in. Used some quicksteel to lock it into place, fixed. at least for now. had to get new vent and filler neck lower hoses...it's all back together and running. still have to do the fuel filter.
Edit: Here's a pic of the repair
Old Nov 4, 2011 | 11:31 PM
chris015's Avatar
that'll work! for now at least..Ive never messed with those,as my 1st gen doesnt have one.
Old Nov 5, 2011 | 11:15 AM
pettyfog's Avatar
Mike I hope that works out for you but I have more faith in fixing the broken nipple, than in trying to glue or epoxy something to the tank plastic... which is what I tried to point out. Besides it's faster and cheaper.
Maybe I better write that up as a standalone.
DONT FORGET THE FRONT VENT..either disconnect it at the frame side or just cut the tubing at 1 inch from clamp.
{ I forgot and dropped the tank with it still connected and broke the vent nipple.
At any rate,now I had the tank out, I saw the pump was the original. The lock ring was nothing but a cluster of rust. So another trip. Checked the parts stores, they dont have either the ACDelco {P/n TR 14} or the Dorman equiv.
To the dealer.. $26 for the ring
To the Hobby Lobby store 5/32" brass tube, package of three for $3.99.
- I'd checked the vent nipple ID with drill bits. 9/64 passed, 5/32 wouldnt, so 5/32" is what I wanted.
Click image to enlarge
The first thing to do was test the stuff I wanted to use for crack sealer. I've never had much luck with epoxies on plastics, especially slick plastics that would flex, as this nipple surely would. The idea was to smear a thin layer of Plumber's Goop (TM) and let it dry while I was tending to removing the pump.
I cleaned an area on the vent valve and primed it with the standard purple plumbing primer. It's rated for PVC and ABS but I'd used it to remount mirrors with standard gel superglue and it seemed to work fine.
Then started on getting the fuel pump ring loose. The secret is to clear the rust out of the intersecting points of the ring and tabs that are molded into the tank. To do that I used an old screwdriver and hammer at a 45 deg angle. The caked rust will fall off as you tap it but it's tedious and you dont want to destroy the tabs. Once I could see the actual lines where the tabs come trough, I tapped firmly down on the ring next to tabs.
Then tapped the ring around until there was pressure on the plastic 'keeper' flip the keeper out and it's easy.
Now I got out my compressor and blew away all the rust and debris. Else use a shop vac or steel brush with vacuum cleaner.
I put the new pump and lock ring in immediately and started on the vent nipple fix.
I scratched the test spot and saw the Goop adhered pretty well. I put a few drops of gasoline on it and found it held up well, just got a little slick on the surface.
Then I marked the 5/32 bit for penetration and made one pass through the nipple, keeping the drill running as I withdrew it. Only took out a thin shaving.
Click images to enlarge
I drilled the length of the passage but realized later it would have been better to stop just a little past the crack so the tubing would have sealed even better.
Then I primed and, while lifting nipple a little, sealed the area just around the crack using the Plumber's Goop.
I marked the 5/32 tubing for the full length of the nipple passage, cut and deburred then tapped it in till it was even with the end.
Old Nov 5, 2011 | 04:21 PM
Well that repair lasted all of one day. Don't use quicksteel.
Bought a plastic welder and some abs rod. That'll do it. If I don't explode.
Tried finding a replacement tank to no avail. Dealer wants $900. No thanks.
Pettyfog thanks for the advice but the way the nipple was broken and the top of the valve twisted (tank got dropped full) it would have leaked regardless. And it's unfortunately too late for that now
Old Nov 5, 2011 | 06:19 PM
chris015's Avatar
there is a ton of fuel tanks on ebay for less then 150 bucks!
98 blazer fuel tank | eBay
Old Nov 5, 2011 | 08:47 PM
None of them are right. I was looking on there....apparently it's hard to find the proper tank. Apparently there are NO aftermarket companies that make these damn plastic tanks....... and GM wants $900 for the tank...but they'd have to locate one because i was told it was discontinued.
Old Nov 5, 2011 | 08:50 PM
xgiovannix12's Avatar
junk yard ?
Old Nov 6, 2011 | 10:25 AM
junk yards within 100 miles of me (maybe even all of PA) punch holes in the tanks to drain them when they come in.
Edit: WELLLL a lil update......I located a tank. Used...in a junkyard, in Texas. Ordered it.....let's all learn from my screwup, even plastic welding had some small pinhole leaks. I did it properly but just the act of moving around the plastic and melting it together it seems made tiny little air pockets that turned into holes.
shotnva777
Oct 13, 2011 09:53 PM
matt92
Aug 24, 2011 06:22 AM
JRob238
Feb 5, 2010 05:02 PM
Blazin_1t_up
The Chop Shop
Sep 14, 2008 12:32 AM
88s10Blazer
Dec 12, 2006 01:08 AM
