Time to sell the Blazer?
Old Feb 24, 2012 | 10:58 AM
  #21
Defiant's Avatar
Defiant is on a distinguished road
Originally Posted by Smitty Smithsonite
We ran 20W-50 in ours all last winter on the old engine. Some mornings below zero. Had a hard time turning over, but it still ran. That stuff will hardly pour below 20° so we had to leave the oil in the house just to get it out of the container quickly.
Still went through a quart every 50-100 miles, which was every day - right out the tailpipe in a massive cloud.
And out goes your o2 sensors lol.
Old Feb 24, 2012 | 11:15 AM
  #22
70Camaroman's Avatar
70Camaroman is on a distinguished road
Originally Posted by vortec bowtie
Just a little update... Ive decided not to get the oilpan gasket done. Ive driven it how it is sense my last post, and it has not leaked anymore oil, and i have not had to add any. The squeeking also pretty much stopped, and im honestly not that worried about it. Im gonna do the trans seal in my autoshop class and change out the tranny fluid, filter, and gasket. Im also due for an oil change next week. Im wondering if theres anything I can add to my oil to cure any possible leaking gaskets? Or if running high mileage oil will help? I know theres plenty of threads on here about high mileage oil and i hear good and bad. If I swich to high mileage oil, and it works out with no leaking, ill keep running it. So whats some opinions on this? Run high mileage oil or keep running what ive been running, which is conventional mobil superclean 5000. Ive decided i like the blazer to much to sell it, plus I just got HIDs for it lol
Stay away from oil system leak stoppers!!! They expand the rubber seals and usually stop the leaks until you change the oil again. Additionally they swell all seals not just the one that is leaking. You state that the oil pan leak seems to have stopped. Just for good measure you might want to make sure the pan bolts are tight. The oil pan gasket is a set thickness and can't be over tightened. Don't go nuts but make sure they are tight. You would be amazed at how often these bolts work themselves loose. Yes, oil pan gasket replacement is a pain. You have not mentioned that your truck is smoking or using oil. High mileage oil is basically oil which is designed for high wear of piston rings and valve seals. I would imagine that it has a thickener (sticky component) much like the no smoke which is also available at auto parts stores but not advisable to use. 10w30 is fine for winter but 5w30 would be better if the truck doesn't start using it. Keep in mind that the thinner the oil is the better fuel mileage your vehicle will get. You just need to find the lightest oil you can use without the truck using oil. When engines use oil they tend to plug up the catalytic convertor and mess up oxygen sensors.
Old Feb 24, 2012 | 11:33 AM
  #23
I dont kno what to do at this point. If i sell it and get something else, the next car could be problem after problem too. If I decide to get it fixed, I want to get everything fixed and make it perfect. Lately its been running really sluggish it seems and hesitates at wen the throttle is applied at like 1500 rpms. No codes are being thrown or anything. When it gets nice out Im gonna do my plugs and wires, if i keep it.
I had a 98 Blazer which did exactly the same thing when I first bought it. If you do not already have one get a fuel pressure test gauge and check the trucks fuel pressure (key on engine off). The place to hook the gauge up is just in front of the distributor and towards the drivers side. You should get 58 to 65 PSI of fuel pressure. If you do not, to rule it out, change the fuel filter which is located on the frame under the drivers seat. If the fuel pressure does not change and is still low the problem, which is super common in these trucks, is more than likely the fuel pump assembly. In tank! Bummer!! Not to worry, it really isn't that difficult to do or maybe I am saying that because I have done a few. Takes me less then an hour now. Just a good pointer. Before you do anything "carefully" remove the vent hose from the front top of the tank (at the tank not the steel line) because this will cause you to break the plastic nipple requiring that you buy a replacement fuel tank.
btw, Sea foam fuel system cleaner which was mentioned earlier in this thread is awesome.
Old Feb 24, 2012 | 12:11 PM
  #24
vortec bowtie's Avatar
vortec bowtie is on a distinguished road
70camaro, thanks for all the advice so far. With eevrything youve said in mind, im gonnna change it with what ive been using, mobil conventional superclean 5000. While Im changing it I will also check to make sure all the bolts are tight. Im hoping they are a little loose and thats causing me to sometimes use a little bit of oil. As for the fuel filter, that was just replaced, along with the fuel pump, which I went with the oem ACDelco pump. So i dont think thats where the issue lies. Thanks for all the responces and ill keep you updated after i do the oil change
Old Feb 25, 2012 | 09:34 AM
  #25
Have you acquired a fuel pressure gauge yet and found exactly what pressure the system has? I know that stores like Autozone and Oreilly's lend out tools for free. Not sure if they have fuel pressure gauges to lend out but it doesn't hurt to check instead of buying a tool you might use only once or twice. You just have to give them a deposit which you get back upon returning the tool. This is a must in troubleshooting such a problem. Otherwise you might be throwing money away by troubleshooting by installing new parts to find the problem. That gets expensive quick!
Old Feb 25, 2012 | 09:39 AM
  #26
fuel pump was changed a few months ago and it still did the little hesitation thing right after it was done. When it was tested after the pump was done, it was at like 60 i believe
Old Feb 26, 2012 | 11:25 AM
  #27
Never assume or guess fuel pressure when troubleshooting. It only ends up with you buying parts which don't need to be replaced making you chase the problem. New fuel filter, check fuel pressure, if low pressure still then pressure regulator. If pressure is within specs I would first start with the simplest procedure by running a quality / strong fuel system cleaner like Seafoam through the system to see if it cleans out the system and corrects the problem. Unlike other vehicles, to my knowledge, the Blazer does not have a place to pinch off the return line to the tank to test the pumps ability to pump max pressure without running the risk of damaging the plastic line. I would be afraid that the plastic line would crack. If all else has been verified to be good the only remaining part is either the fuel pressure regulator or plugged injectors. The regulator is part of the injection spider. I recommend changing the spider but it is more money. If money is tight then just swap out the regulator. Plugged injectors can cause the same issue and since you have the top of the intake manifold taken apart anyway I would just change injector spider. I hate doing work twice.
Old Feb 27, 2012 | 09:01 AM
  #28
Smitty Smithsonite's Avatar
Yep - that spider is the biggest abortion ever created by GM.
chesthing
Feb 1, 2010 05:34 PM
lionel2
Apr 16, 2008 04:45 PM
igot10pinitis
Nov 21, 2007 02:44 PM
GMdesigner
Jul 27, 2007 11:15 PM
