upper display 1998
Isn't there a way to toggle that display setting between on and off? I sold off the Blazer a while back, but going from memory, thought I had turned that display off once. . . . Could it be that simple? Seem smore likely than a fuse., IMO.
Due to the proximity to the roof and the lack of insulation above it, those modules are starting to have a reputation for going out on the older rigs among us due to heat stress induced failure. Try adjusting your cab dimmer switch and see if you can see anything at all, and failing that i will try to find a wiring diagram for it so i can point you in the right direction for diagnostics.
ayla
03-03-2014 08:17 PM
DaddyCop03
05-11-2008 09:07 PM
