Worth the money?
Old Jan 18, 2009 | 05:12 PM
jackedUPk5's Avatar
jackedUPk5 is an unknown quantity at this point
Default Worth the money?
Looking at buying my first vehicle. A 1976 K5.
Originally they wanted $700.
Needed a starter, heater core, and blower motor assembly.
Now they bumped it up to $850, because they put the starter in yesterday.
Body is in good shape. Original 6.6L (400ci) small block engine and TH400 tranny with 92,000 miles.
Worth the money or what?
Old Jan 18, 2009 | 05:25 PM
Default RE: Worth the money?
It does not look too awful bad.
I bought mine for $400 running, driving, and requiring only body work (although I am in the process of installing headers and a new exhaust system).
Here is a pic of mine:
You will want to make sure that the body mounting locations on the body are not rotted out, that the rear support that runs across in front of the tail gate is not rusted out, and the rockers... Pictures are not that great, but it looks like the driver rocker is rusted quite badly and the passenger side is bulging too.
Old Jan 18, 2009 | 05:32 PM
jackedUPk5's Avatar
Yeah, I looked at your post, looks like a nice truck, even before the work that needs to be done.
I was really excited when I looked and found a bunch of possibilities for this thing.
They're endless. And so are replacement parts! Cheap as can be!
Anyone know of some good places to get some standard specs for this truck?
The main thing I'd like to know is tire sizes that will fit.
But anyone that can find a general specs list, would be my new god for the time being.
Old Jan 18, 2009 | 07:44 PM
Year:: 1976
Production Total:
74,389
Base Price: 5,365
Weight: 4,017
Wheel Base: 106.5 in.
Fuel Tank Capacity: 20-gallon/31-gallon
Length: 184.5 in.
Height: 71 in.
Std. Engine, (net HP): OHV Six-cylinder 250 cid. (100) @ 3600 rpm
Opt. Engine, (net HP):
OHV Eight-cylinder 305 cid. (130) @ 4000 rpm
OHV Eight-cylinder 350 cid. (160) @ 3800 rpm
OHV Eight-cylinder 400 cid. (175) @ 3600 rpm
Rear Axle: GM Corporate 12-bolt (8.7/8-in. 1.31 Axle Dia. 30 Spline)
Front Axle: Dana 44 (8.5-in. 1.31 Axle Dia. 30 Spline)
Transmission (M):
SM318/SM326/SM330/T-89A/T-150 3 spd. (2.47-3.50:1 First Gear)
SM465 4 spd. (6.55:1 First Gear)
Transfer Case (M): NP205 (1.96:1 Low Range)
Transmission (A): TH350 (2.52:1 First Gear) TH400 (2.48:1 First Gear)
Transfer Case (A): NP203 (2.01:1 Low Range)
Notes:
A major development of 1976 was a new body design, it featured a steel half-cab with an integral roll bar built into the steel front compartment roof and lock pillar structures. Available at extra cost was a removable fiberglass-reinforced plastic roof that attached to the pickup box with 16 bolts.
As far as lift vs tires... I do not have any solid information for you. I have a 3" body lift on my K5 with stock suspension, 33x12.5x15 tires on 15x10 aftermarket rims with less back spacing than stock. My fenders are trimmed although I am not too sure that it would be necessary (was done before I bought it).
Old May 30, 2009 | 07:02 AM
Brian<3Chevy's Avatar
Brian<3Chevy is on a distinguished road
Stupid Question, Will the SM465 Trans bolt straight up to an NP203 Transfer Case? trying to do a manual conversion, tryin to save a little money by keepin the stock transfer case
NCSWP
Suspension Tech
Apr 21, 2011 12:16 AM
Idriveachevy
Nov 19, 2007 07:38 PM
BLK85
Jun 17, 2007 11:48 AM
jadewolf32
Jul 11, 2006 03:35 PM
kornphlake
Apr 19, 2006 05:37 PM
