General Tech Help Good at troubleshooting? Have a non specific issue? Discuss general tech topics here.
CV Shafts
Old Aug 13, 2006 | 02:40 AM
ceanern's Avatar
ceanern is an unknown quantity at this point
Default CV Shafts
Would you recommend Changing out cv shafts. or just redoing the boots. The one has been leaking for 1 yr maybe 2 yrs. The other one just started this spring. and the boot came clean off the drivers side. The last trip out. Which would be wiser or easier or should I check my knuckles out and see if they look ok?
Old Aug 13, 2006 | 02:46 AM
Default RE: CV Shafts
I would straight up replace them. With the availability of parts, it just doesn't make sense not to if you can do the work yourself. Properly replacing the boot requires the removal and disassembly of the CV shaft anyhow.
Expect to pay around $120 for new and $80 for reman CV shafts.
Old Aug 13, 2006 | 05:13 AM
Annekat91's Avatar
Annekat91 is an unknown quantity at this point
In case you don't want to do it yourself, I had a remanufactured one installed at a Midas shop for about $200 parts and labor a year ago, which was at least $50 less than other places I called or heard about. I didn't have them do the other one because, although it had a small tear at one end of one boot, it didn't seem to be leaking. I should probably look at it again, though.
Anne
'91 2dr S-10 Blazer
Old Aug 13, 2006 | 01:10 PM
lastcoupe's Avatar
lastcoupe is an unknown quantity at this point
Definitely take Kyle's advice on this, get you some reman complete axle shafts and be done with it.
harley745
Nov 6, 2012 08:13 AM
DreezyBeezy
Jun 10, 2012 05:29 PM
Diverknox
May 17, 2011 01:09 PM
Leearchibald
Sep 17, 2010 11:10 AM
mav06
Dec 13, 2009 02:20 PM
