General Tech Help Good at troubleshooting? Have a non specific issue? Discuss general tech topics here.
Front wheel hub or bearing change?
Old Nov 8, 2006 | 06:25 PM
Marcin's Avatar
Marcin is an unknown quantity at this point
Default Front wheel hub or bearing change?
Hi
I need to replace front wheel bearing. As I know in American cars it is only possible to change all hub not only bearing. But one told me that it should be possible to change only bearing (suggest was to use Timken bearing) which should be much cheaper than changing all hub. Have you ever tried to change bearing only instead all hub?
Marcin
Old Nov 8, 2006 | 06:33 PM
Default RE: Front wheel hub or bearing change?
On the 4wd, it is an integrated hub/bearing. You need to remove the wheel & brake components, then remove the 3 bolts holding the hub to the steering knuckle and remove the axle nut. Press the axle out of the hub and pull the hub from the steering knuckle. Reassemble reverse of removal. If you need the torque specs, please let me know.
Old Nov 8, 2006 | 06:40 PM
Marcin's Avatar
Thanks for information but it is not too good news. Wheel hub in Poland costs 300USD Could send me torque specs? I hope to find it in Haynes manual but it should arrive next week or later.
Marcin
Old Nov 8, 2006 | 09:23 PM
Mbastet99's Avatar
Mbastet99 is an unknown quantity at this point
Too bad you couldn't find a way to ship one from the US....I've been checking them out for my Blazer also, and they run around 150USD here. Wonder if you could get them shipped from any company? Not sure how long that would take, though. It'd be like a 2-for-1 sale!
Old Nov 8, 2006 | 09:32 PM
magtec's Avatar
magtec is an unknown quantity at this point
i imagine the price to ship would be considerable. not only is the item not light, but you're shipping internationally.
Old Nov 9, 2006 | 02:17 AM
Mbastet99's Avatar
Yes, I know that (I used to work for Airborne Express), but I can't imagine that it would be $300. Maybe I'm wrong, with the price of fuel!! Figured it might be worth a shot if he doesn't need them ASAP.
Old Nov 9, 2006 | 04:05 AM
Chevy Lover's Avatar
Some specs for you, and some that you don't need right now.
Fastener Tightening Specifications
Application
Specification
Metric
English
Ball Joint Nuts (Replacement Joint)
23 N·m
17 lb ft
Drive Axle Nut
140 N·m
103 lb ft
Lower Ball Joint to Steering Knuckle Nut
108 N·m
79 lb ft
Lower Control Arm Bumper Nut
25 N·m
18 lb ft
Lower Control Arm to Frame Front Pivot Bolt (RWD)
115 N·m
85 lb ft
Lower Control Arm to Frame Nut (4WD)
110 N·m
81 lb ft
Lower Control Arm to Frame Rear Pivot Bolt (RWD)
98 N·m
72 lb ft
Shock Absorber Lower and Upper Nuts (4WD)
73 N·m
54 lb ft
Shock Absorber Lower Bolts (RWD)
30 N·m
22 lb ft
Shock Absorber Upper Nut (RWD)
12 N·m
106 lb in
Spindle Nut
16 N·m
12 lb ft
Splash Shield Bolts (RWD)
26 N·m
19 lb ft
Stabilizer Shaft Bracket to Frame Bolts (4WD)
65 N·m
48 lb ft
Stabilizer Shaft Bracket to Frame Bolts (RWD)
36 N·m
26 lb ft
Stabilizer Shaft Link to Lower Control Arm Nut (4WD)
15 N·m
11 lb ft
Stabilizer Shaft Link to Lower Control Arm Nut (RWD)
18 N·m
13 lb ft
Tie Rod to Steering Knuckle Nut
53 N·m
39 lb ft
Torsion Bar Support Lower Link Nut
50 N·m
37 lb ft
Torsion Bar Support Upper Link Nut
65 N·m
48 lb ft
Upper Ball Joint to Steering Knuckle Nut
83 N·m
61 lb ft
Upper Control Arm Bumper (4WD)
27 N·m
20 lb ft
Upper Control Arm Shaft Nuts (RWD)
115 N·m
85 lb ft
Upper Control Arm to Frame Nuts (4WD)
115 N·m
85 lb ft
Upper Control Arm to Frame Nuts (RWD)
75 N·m
55 lb ft
Wheel Hub and Bearing Assembly to Steering Knuckle Bolts (4WD Pickup and Utility)
105 N·m
77 lb ft
Wheel Speed Sensor Bracket and Brake Hose Bracket Nuts
24 N·m
18 lb ft
Wheel Speed Sensor to Wheel Hub and Bearing Assembly Bolt (4WD Pickup and Utility)
18 N·m
13 lb ft
Old Nov 9, 2006 | 11:31 AM
Marcin's Avatar
Thanks for help and information. I foung wheel hub in Poland for 200USD what seems to be acceptable price.
Reagrds, Marcin
88s10Blazer
Jun 4, 2010 04:56 PM
johnsonmopar
Mar 10, 2008 06:49 PM
Maldo15d
Tires and Wheels
Jul 26, 2007 06:59 PM
bigrackhunter50
Apr 11, 2007 01:08 AM
Chavez96
Sep 20, 2006 04:04 PM
