General Tech Help Good at troubleshooting? Have a non specific issue? Discuss general tech topics here.
Fuel Gauge
Old May 17, 2006 | 10:36 AM
aikvenger's Avatar
aikvenger is an unknown quantity at this point
Default Fuel Gauge
My fueld gauge when I first start the engine bounces from full to empty rapidly. After the engine has run for a few minutes the gauge settles but it never goes below the half tank mark. What could be wrong?
Old May 17, 2006 | 10:46 AM
Default RE: Fuel Gauge
Fuel level sender has started to go bad. In most applications, the sender is part of the fuel pump and is not separately replaceable. Not to mention that you have to drop the fuel tank to get to the sender and pump. It could be a wiring fault, but again, you'd have to drop the tank to access the wiring on top of the tank to troubleshoot further.
Please include atleast the year of vehicle you are posting about in every thread you start. It helps us to better analyze your situation.
Old May 17, 2006 | 12:34 PM
MCas86's Avatar
MCas86 is an unknown quantity at this point
i have this problem too but im just to lazy to fix it, i just dont let it go under half tank bc thats when it starts goin haywire
Old May 17, 2006 | 07:49 PM
jagblazer01's Avatar
ORIGINAL: swartlkk
this is correct....i had the same problem with my 01. It was the fuel sending unit inside the tank which is a part of the fuel pump. only way to fix it is replace the pump.
grayman63
Jul 17, 2013 01:56 PM
JonZRDeuce
Feb 5, 2012 06:38 PM
hoppy26
Jan 26, 2012 02:08 PM
Mulisha
Mar 24, 2008 09:14 PM
