General Tech Help Good at troubleshooting? Have a non specific issue? Discuss general tech topics here.
Knob under driver's seat
Old Oct 4, 2006 | 10:15 PM
Default RE: **** under driver's seat
If it does go to the front diff, most likely someone put in a manual disconnect for the front diff instead of running with the vacuum diaphram actuator to lock it in...
Old Oct 5, 2006 | 12:44 AM
USMaverick101's Avatar
USMaverick101 is an unknown quantity at this point
hey im sorry it goes to the REAR differential
Old Oct 5, 2006 | 01:58 AM
20Blazer00's Avatar
ORIGINAL: USMaverick101
Well I am just guessing but it might be some type of manual locking mechanism for the rear axle....Duh
The only way to find out is to either try it out or take it to a tranny/rear end shop to see if they can explain it to you.
Old Oct 5, 2006 | 12:25 PM
what would locking it do? why and when do i need to do this?
Old Oct 7, 2006 | 01:41 AM
tycobb280's Avatar
tycobb280 is an unknown quantity at this point
locking the diff. just means that youre locking the gears inside together so both of the tires will spin in a low traction situation instead of just one tire spinning like with an open diff. if its engaged and youre on dry pavement and you hear the tires chirping when you turn, its a locker. if the tires dont chirp then more than likely its not a locker, or its not engaging properly.
njk53
May 20, 2011 05:16 AM
kickme005
Sep 6, 2010 06:03 PM
classklown90
May 18, 2009 11:45 AM
oktain
Oct 21, 2008 02:45 PM
drperry
Apr 13, 2007 08:51 PM
