easy way to lift
Old Jan 16, 2011 | 08:52 PM
CarThrower's Avatar
CarThrower is on a distinguished road
Is that price range for the whole kit?
Old Jan 16, 2011 | 08:58 PM
awbolton66's Avatar
awbolton66 is on a distinguished road
yep and you can put 2" shackles on the rear end and the torque torsion bars 1.5" not to more either can be hard on the front end
Old Feb 18, 2011 | 08:46 AM
chevyguy4lyfe's Avatar
chevyguy4lyfe is on a distinguished road
Old Feb 18, 2011 | 09:31 AM
s14sh3r's Avatar
Personally, I'd go with the body lift. Keep in mind that with the stock rims, 31 inch tires will likey rub the frame and/or sway bar at full lock. You can buy rims with less backspace, but then you run into problems with the tires rubbing on the back of the front fenders. There are several guys on here who's tires rub the frame at full lock, but they don't seem to make a big issue out of it. You lose a little bit of turning radius is all.
Old Feb 18, 2011 | 10:09 AM
Benedict1337's Avatar
you can run 31's with a 2" lift and stock rims without rubbing, offset rims you have to trim your fenders.
List of lifts.
tbar crank 1-3" - free
shackles 1-2" - $50
add-a-leafs 1" - $75
body lift 2" - $200
rough country 2" susp - $425
superlift 2" susp - $800
bds 5" susp - $1600
superlift 6" susp - $1900
the largest possible lift you can get is with tbar crank, shackles, body lift, and the 6" superlift. thats 10" of lift and you can maybe squeeze 35s depending on the brand. any tire size larger than 31's you may have issues rubbing the frame and or sway bar.
or you can do a solid axle swap and you can lift your truck from anywhere from 4-20" cost you about $2000, not counting tires, gears, ect.
Old Feb 18, 2011 | 04:41 PM
HcHawks09's Avatar
lol VERY well said
Chevymarine
Lifting Tech
Feb 20, 2011 12:48 PM
rastoma
Dec 29, 2009 12:37 AM
FlatTopFoley
Dec 17, 2009 09:25 PM
kurslt
Oct 14, 2009 06:21 PM
Buschkj24
Oct 9, 2009 06:08 AM
