New to lifting
Old Jul 21, 2008 | 08:53 PM
THEGOAT's Avatar
THEGOAT is an unknown quantity at this point
Default New to lifting
I just got a 98 blazer 4 door 4x4 and i was wondering if i get a lift kit smaller than 3 inches will i need to buy any other parts thanks any info appreciated
Old Jul 21, 2008 | 09:17 PM
riceh8r0512's Avatar
riceh8r0512 is an unknown quantity at this point
Default RE: New to lifting
A 1.5" torsion bar front lift and 2" shackles in the rear are your cheapest option. Lifting these trucks causes a lot of stress on the front ends and will cause premature wear. The lift kits that will do 2" achieve the same thing as above, except they may include stuff such as new torsion keys so that you can crank it more, but the more you crank, the sooner you will blow your front end parts. (If I remember right someone on here said at 2" on the torsion bars it was only 50 miles till something broke). If you do lift it just remember to keep things greased and that will help. There is a thread that will describe all the different lift options available, search for it.
Old Jul 21, 2008 | 10:43 PM
WolfPack's Avatar
Very true.
As for other parts, you don't really NEED any other parts, but you'll want to consider longer lift shocks (+1 or +2), greasable ball joints, and maybe a small fund for tire rotation
Old Jul 22, 2008 | 01:34 AM
tjwiens91@hotmail.co's Avatar
tjwiens91@hotmail.co is an unknown quantity at this point
Couldnt you just buy a 2 in. suspenion lift? you get front end parts with that right?
Old Jul 22, 2008 | 07:45 AM
WolfPack's Avatar
If you buy the full kit from Rough Country or Superlift you'll get new shocks all around, and the RC kit comes with upper ball joints. If you just do the more common tbar crank/shackles, you get none of that, but you save $340+
Old Aug 7, 2008 | 03:58 PM
trobbins's Avatar
I just got a 97 4dr 4x4 and was wondering the what the cheapest 3" lift i can get and cheap brushgaurd and what size tire will clear without rubbing?
Old Aug 8, 2008 | 02:52 AM
WolfPack's Avatar
well...i'm feeling nice...so i wont just tell you to go search as this has all been covered...
So...3' of lift for your truck will be either a 1' suspension lift (shackles and t-bar) + 2' body lift. Or you can go 2' suspension (harsher ride) and 1' body lift (custom kit)
Brush guards arn't cheap. You can find Hunter guards (ordered direct from manufacturer) for ~$220, or go with pre-fab for $350-400.
Largest wheels you can fit are 30x9.5 with no lift. If you lift 2' you can fit 31x10.50. If you throw new rims on with different backspacing, you run into a whole different set of limits.
thanny72
Lifting Tech
Aug 16, 2011 11:48 PM
hawghunter1
Lifting Tech
Sep 21, 2009 02:27 PM
mhollis
Tires and Wheels
Jul 26, 2009 08:41 AM
Big Frost
Lifting Tech
16
Oct 7, 2008 07:50 PM
Chriss721
Lifting Tech
Jun 18, 2008 09:25 PM
