Simple question..I think.
Old Feb 7, 2012 | 09:44 PM
97cherryblazer's Avatar
97cherryblazer has a spectacular aura about97cherryblazer has a spectacular aura about
OOPS well i guess i should read into things before i open my mouth lol. I guess we were both looking at this the wrong way. but that does make sense now. So just think of it as a frame lift instead a diff drop.
Old Feb 7, 2012 | 11:16 PM
oktain's Avatar
Originally Posted by j89lumaye
You got it all wrong here
You put in the diff drop brackets so you dont have to crank the t bars up
So say you buy the RC 2.5 lift kit. You get 2 inch shackles in back, then 2.5 up front. You can also crank your bars then, which would give you up to 5.5 up front, but that would be when you wear out cv's and everything
HUGE correction. The differential drop is only to lower the front differential. Cranking T-Bars is required to get the 2" of lift, but the diff is lowered to keep CV angles. You CANNOT get 5.5 inches out of any T-bar crank. Go take a look at how your Blazer is put together with the IFS, it'll all make sense.
Old Feb 8, 2012 | 12:48 AM
Chuk Rhodes's Avatar
Chuk Rhodes is on a distinguished road
One last comment on t-bars, they are your springs, not just a lever to adjust ride height.
I started messing with mine cause I could see the front sag, more so on one side, which surely means wear on the t-bar (weakend spring). I have one side (previously lowest) nearly all the way in, now 1.5" over where it was, which I figure is about a 1" lift from where it should have been. I simply cannot go farther than 1" lift with stock keys. Any further raising, arms or ball joint spacer, and I'll need new keys to keep the current spring load.
To solve that problem, I'm looking at Suspension Maxx SMX-MCS10. I really like the idea that the hex insert can be adjusted, sort of like "ratcheting" it back to continue cranking. Seems like it's one part that can be set to any height range. Anyone out there using these? Have pros/cons?
Old Feb 8, 2012 | 01:02 AM
pettyfog's Avatar
content deleted ... Cause I cant delete the post..
adaptechsolution
Apr 7, 2012 12:03 PM
thebigjimmy
Dec 22, 2009 10:38 AM
BIGGER_HAMMER
Nov 21, 2008 02:00 PM
mudsliner
Nov 26, 2006 12:56 AM
4WDBlaze
Engine & Internal
Oct 20, 2005 12:05 PM
