tbar crank and shackles
Old Jun 2, 2009 | 10:27 AM
  #31
burningsun's Avatar
From: Eternia in the winter and Metropolis in the summer.
burningsun is an unknown quantity at this point
I just want to add a reminder that if you do crank the t bars without the new control arms you will not get a good camber. And I will find a more durable cv axle, It maybe *** simple as adding an inch to the shaft of the CV axle. That may change the geometry enough so that the angles will lessen.
Old Jun 2, 2009 | 05:36 PM
  #32
cr8390's Avatar
cr8390 is an unknown quantity at this point
i want 2 crank mine but im not ready yet haha i cranked them 1/2 inch to even out my sagging and the passenger cv started spewing grease clean that all up and 2 weeks later the cv axle seal and output shaft bearing went. Not saying the could be cause of the tbar crank put the problem arose when i cranked them just that little bit
Old Jun 3, 2009 | 10:32 AM
  #33
burningsun's Avatar
It was likely the the CV boots time. I almost want to say if you got over a hundred thousand miles just replace the axles. Especially if you touch the torsion bars. I may even add a few thick washers or connect a cable to the upper or lower control arm from about where the shock bolts to the frame so that the wheel can't drop lower than it does when setting flat.. this will keep the axle from exceeding the safe angles when you get a tire in the air. It'll take some wheel travel away though but till I get this CV axle thing whipped It may have to do.
Old Feb 24, 2012 | 02:05 PM
  #34
ryda's Avatar
ryda is on a distinguished road
did a tbar crank and shackles cannot get the alignment quite right and now both inner cv boots are spewing grease out of the inside edge how can i stop this, clamps new boots any info would help and i am going to do the upper ball joint flip to see if that helps alignment
Wisco Blazer
Lifting Tech
Aug 18, 2012 04:01 PM
BlazHerZR2
Lifting Tech
Nov 11, 2011 07:23 AM
sk8indigomoon247
Lifting Tech
Aug 19, 2009 10:45 AM
jdblazin
Lifting Tech
Nov 21, 2007 07:06 AM
jimmyboy
Tires and Wheels
Dec 4, 2006 09:46 PM
