1996 blazer turn signal issue
Old Dec 17, 2013 | 12:12 PM
rock_fan87's Avatar
rock_fan87 is on a distinguished road
well i replaced the front portion of the wiring harnes for the lights and the multifuntion switch and i still dont have any turn signals now the right turn signal indecator light is on when i turn on the head lights
Old Dec 17, 2013 | 01:47 PM
Diaita's Avatar
Sounds like something isn't grounding properly? Have you checked continuity for all the wires?
Old Mar 20, 2014 | 07:07 PM
Bazz Smitbar's Avatar
Bazz Smitbar is on a distinguished road
I have a problem with my direction indicators, sometimes they don't work but if I turn the hazard lights on, then the direction indicators work? Do they all work off the same unit? It is easy to pop it out of the dashboard..
Old May 5, 2014 | 05:18 PM
This was the source of my problem, just plugged a new one in, sorted....
Attached Thumbnails 1996 blazer turn signal issue-chevyhazardenlarged_zps11533b0a.jpg
Old Mar 5, 2015 | 03:18 PM
sailorjeremy90's Avatar
sailorjeremy90 is on a distinguished road
So you swapped the hazard's switch and now your turn signals work? I'm having a similar issue, my turn signals don't work but the hazards work, head lamps come on when I turn the lights on but just no turn signals.
Old Mar 6, 2015 | 04:00 AM
Barry Smithson's Avatar
Barry Smithson is on a distinguished road
Yes, brought into the UK via USA Automotive, I also bought a flasher can but didn't need it. If your other lights all work etc and also hazards I would swap this first. On mine it was an intermittent problem, if the side indicators didn't work I turned the hazards on for a second or two, cancelled them and then side indicators worked for a while. It cost me £200+ so not cheap, maybe $300 to you but knowing UK import duties and VAT I probably got clobbered lol. Dead easy to swap, no worries. DONT remove the whole dashboard, just the cover that plugs in with the switch in it, then it plugs in easily with a multi connector. I had to drill out a hole for the red LED alarm flasher, the cover isn't drilled for it from memory.
Hope this helps
Old Mar 28, 2015 | 12:43 PM
How did you get on..? Sorted?
SubbinBlazer
May 24, 2013 12:56 PM
ta3ff
Oct 14, 2009 05:07 PM
greengoose89
Feb 11, 2009 09:07 PM
KSEScream420
Dec 31, 2008 09:24 AM
shaka1111
Feb 13, 2006 02:23 PM
