Day Night Mirror
Old Dec 5, 2010 | 11:39 AM
2000jimmbo4x4's Avatar
2000jimmbo4x4 is on a distinguished road
Default Day Night Mirror
i was at the local pull a part today and found a day night mirror out of a bravada without onstar. the wiring is intact. my question is are there plugs up in the headliner for this option? ill eventualy go look but im wondering if anyone knows. my truck is a 2000 jimmy SLE
Old Dec 5, 2010 | 03:30 PM
There likely won't be a plug for the mirror in the head liner. You basically need power, ground, and then a wire from the back-up circuit to keep the mirror from dimming when you are in reverse.
What year was the Bravada? I can pull a wiring diagram for you once I know that.
Old Dec 5, 2010 | 03:47 PM
i do believe it was a 99. the mirror i have has a 3 wire plug and a seperate 2 wire plug. will it work without the reverse circut?
Old Dec 5, 2010 | 03:59 PM
The 3 wire plug is the power, ground, and back-up wires. The 2 wire plug is for the courtesy lamps under the mirror. Here's the diagram:
Old Dec 5, 2010 | 05:47 PM
this mirror dosnt have courtesy lights under it. so realisticly all i need is a power and ground for it to work, which if there isnt a a connector i can just tap into the dome lights. thank you for the diagram by the way.
Old Dec 5, 2010 | 05:55 PM
Ground should be easy, but don't pull it off the dome lights. The ground to the dome lights is fed from open door sensors and/or the courtesy lamp relay so it is not constant. Also, I wouldn't pull power from the dome lights either since they are fed +12V constant from the battery, not a switched ignition source.
Power should come from a switched ignition source and then ground to whatever you can that is constant.
Old Dec 5, 2010 | 06:06 PM
ok thanks. il try and find a switched power up there. how many amps dose this draw. cant be much. i could try and locate the switched power for the thermometer/ compass.
also i just went and looked at my harness that i got with the mirror. the wire colors are black (B) green (A)and pink(C). dose the pink substitiute for the brown?
Last edited by 2000jimmbo4x4; Dec 5, 2010 at 06:11 PM. Reason: aditional information
247monster
Nov 29, 2013 09:17 AM
Blazerdazed
Oct 18, 2010 07:58 PM
Unlimitedsp
Jan 1, 2010 08:33 AM
ejschultz
Dec 12, 2009 07:47 PM
XBlazer01
Apr 8, 2006 12:00 AM
