installed these yesterday
Old Aug 22, 2013 | 03:57 AM
95jimmy_slt's Avatar
95jimmy_slt is on a distinguished road
Default installed these yesterday
looks alot better then stock i also installed led bulbs in the turn signal housings
Attached Thumbnails installed these yesterday-1097897_10200106054488569_1884311182_o.jpg   installed these yesterday-1170677_10200106055128585_2136444017_n.jpg   installed these yesterday-1209105_10200106055688599_1194618053_n.jpg
Old Aug 22, 2013 | 08:48 AM
Twip's Avatar
nice, how is the light pattern?
Old Aug 22, 2013 | 12:49 PM
the light pattern actually isnt all that bad it seems to be alot better then the stock pattern which seemed to be blotchy and scattered everywhere and with these ones they have a pretty nice cutoff line and seem to do alot better focusing the light to where it needs to be. i also ran into a turn signal led problem which caused hyper flashing and my turn signal indicators on my dash stay lit so i ordered a electronic flasher relay along with load balancing resistors which i hope will fix the problem.
Old Aug 22, 2013 | 04:43 PM
richphotos's Avatar
You wont need load resistors if you got the flasher..
Old Aug 22, 2013 | 07:24 PM
i know the flasher relay is supposed to fix the hyper flashing but is it also supposed to cure the dash indicator lights also? cuz i have heard that sometimes it wont cure the turn signal indicator lights staying on and sometimes it will and the only lights that are led are the 3157 bulbs and i have heard that you will need one of those resistors behind every led you install for the second gens but im just not sure.
Old Aug 22, 2013 | 09:12 PM
CPLSeraphim's Avatar
CPLSeraphim is on a distinguished road
I have a white blazer, and am planning on getting the same lights, but with the black interior. Those halos look great. Glad to hear they look good and work well. Thanks for the information.
Old Aug 23, 2013 | 11:56 AM
richphotos's Avatar
the LED flasher I got for my jimmy made the dash lights flash normally.
Old Aug 23, 2013 | 05:55 PM
my dash turn signal indicators stay lit saying i have both sides are out but still flash cuz i know they are working which is why i think i need the resistors to help cure that problem so right now i put back in the incandecent bulbs in the turn signals and everything is back to normal until the parts come in
Old Aug 24, 2013 | 06:30 PM
well good news i solved my led turn signal problem you will need a led compatible flasher relay along with load balancing resistors. after installing my dash indicators are no longer giving me a bulb out indication and they flash normal maybe just a fraction of a second faster then stock! side note: make sure you mount the resistors to metal and away from any wiring or plastic as they do get hot.
POS95Jimmy
Nov 23, 2008 07:31 PM
blznlowxtreme
Oct 10, 2007 04:49 PM
BLK85
Street N Strip
Oct 9, 2007 08:52 PM
Loud_01_Blazer
Oct 24, 2006 11:48 AM
88s10Blazer
Jul 24, 2006 02:11 PM
