Left blinker is rapid fire.
Old Oct 28, 2019 | 12:16 AM
LeviM42's Avatar
LeviM42 is on a distinguished road
Default Left blinker is rapid fire.
Hello, I just recently got my first Blazer, and this ride is slick! 95,000 on her, and runs like a charm. I’m wanting to upgrade the headlights to LEDs, but before that, I want to fix one small issue.
So the left turn blinker goes rapid fire when activated, while the right blinker is normal. The blinker also works normally while using the hazards. Could this be a relay issue? Something crossed somewhere?
Admittedly, I’m not very savvy with electronics (or Chevy’s in general, grew up in a Ford house) so any pointers on what to look for on this would be appreciated. This is my first rig that I’d like to take care of, learn more about, and gain some man points in the mechanical department.
Old Oct 28, 2019 | 01:29 AM
GreenBlazer2002's Avatar
Sounds like you have a blown bulb on that side. Check front and rear. You said hazards seem normal. Turn them on then go around the truck and see if one isn't blinking. Do this with parking lights turned on.
Old Oct 28, 2019 | 09:16 AM
LesMyer's Avatar
Remember there is more than one bulb in the tail lights. Compare one side to the other.
Old Oct 28, 2019 | 11:11 AM
LeviM42's Avatar
Okay, I’ll take a look once I get off work, thanks for the tip!
Old Oct 28, 2019 | 07:32 PM
LeviM42's Avatar
Thanks guys! The bottom left bulb was out, so $1.50 Napa replacement bulb did the trick.
blazintexas
May 1, 2012 06:01 AM
ABSLT
17
Jan 16, 2012 11:54 AM
69ER
Jun 10, 2011 02:39 PM
ShagMan
May 21, 2010 05:52 AM
shaunbrown1979
May 5, 2009 06:11 AM
