Rear Defog Wiring
Old Jan 8, 2011 | 10:12 PM
eyeblazin's Avatar
eyeblazin is an unknown quantity at this point
Default Rear Defog Wiring
Anyone ever try to reattach the wire for the rear defog to the rear window? Can it be done?
Old Jan 8, 2011 | 10:26 PM
Rear Defog Broken came up in a quick search.
Old Jan 10, 2011 | 09:43 PM
eyeblazin's Avatar
Thnx Swartlkk!! I did try a search but that thread did not come up
Old Feb 7, 2011 | 09:14 AM
eyeblazin's Avatar
FYI - A Mechanic from a dealership said they would clean the parts and mix copper filings with a strong epoxy and reattach. Haven't been able to try as weather has been to cold.
Old Feb 7, 2011 | 09:55 AM
wade505's Avatar
wade505 is on a distinguished road
If this is the wireing that runs thru the window itself, I had some fair results using a 35 watt soldering iron I use for eletronics to resolder the flat mesh. Remember that gravity works, and too much solder will run back on you! By going at it lightly and keeping the heat at a minimum, you can get the lines to connect. It appears that they do corrode as the lead in the solder returns to lead oxide and thus the connection will go bad. I find this alot in older amps that I repair and used this method to repair my defroster system.
Hope that this helps..
Wade
Blazers.B.Kewl
Jan 14, 2011 02:08 PM
Rags58
Jan 19, 2010 06:21 PM
drummerdude
Dec 27, 2009 10:41 PM
fahzie
Sep 19, 2009 03:12 PM
stevelknievel
Aug 22, 2007 03:12 PM
