windshield wiper fuse keeps blowing
Old Mar 22, 2019 | 07:25 PM
yardbird's Avatar
yardbird is on a distinguished road
Thanks Truk for the support. Would you also agree that both shorts are in the same harness and are connected. And would you happen to have diagrams of the blower motor and blower relay connectors? I won't be able to get on this until Sunday. The weather here in Ma. really wimps.
Old Mar 22, 2019 | 08:03 PM
Trukntigger's Avatar
Yea I can dig up the stuff on Alldata for my 98, should be same or close enough. Most likely short in same loc. Odds are you find the wiper short and the other in same spot. Something has to be rubbing and worn thru to ground it to blow that fuse and HVAC fuse soon as power gose live. In this case, easiest way for you is a digital multimeter that beeps for continuity (short/zero ohms) and a couple of alligator clips. If you have that should be able to locate problem area. Tip: make sure the alligator clip for the wiper connector is small enough to just clip “C” pin and not short to others. False readings from that would make it worse. You can always extend length with extra clip leads. (Small clips tend to have shorter leads) Then like a said just do audible testing. Red to “C” pin and black to ground. If correct I’m thinking will be shorted when you do this and moving the right spot will break the short and beep stops.
Old Mar 24, 2019 | 04:11 PM
yardbird's Avatar
Update. I am 99.9% sure I have found the short. The meter did not work for me. Every time I checked the wires there was constant continuity through the wires I would try to check. Intermittent. I then decided to check why the Underhood HVAC fuse kept blowing. After inspecting the harness I thought to just throw a 15 amp fuse in and see what happens. After five fuses I saw smoke. Question was where was the smoke coming from. Sixth fuse bingo. Seventh fuse I saw the arc I was looking for under and just to the right of the ABS motor. For know I have propped up the harness to prevent it from shorting until I make a game plan on how to approach this fix. From above or below either way it's going to be a bear to get at. Thanks Truk.
Old Mar 25, 2019 | 11:49 AM
go chevy's Avatar
Glad to hear you got it figured out It is always great when someone reports back when they fix the problem...
Old Mar 25, 2019 | 03:51 PM
I’m going to hazard a guess that 1 of 2 things will be needed. On the 1, if lucky can just electrical tape the offending wires and rebundle and zip tie only if the wires themselves are in good shape. If other (2) will most likely have to get a new harness for that section from say a bone yard which while a hassle is really the better overall choice. My preference is option 2, boneyard for a new harness. Seeing you will be working on old first once you get at it should see how hard it is to strip replacement from a boneyard. I’d imagine needs only a few tools like wire cutters, needle nose pliers, couple of flat tip screwdrivers and say scissors to slit plastic sheath if needed. You should post a few photos.
Old Mar 28, 2019 | 10:45 PM
odat's Avatar
Permatex liquid tape works wonders instead of regular roll tape for re insulating wires, works well under heat shrink too.
Old Mar 30, 2019 | 01:43 PM
So any update? Wondering what you ended up doing, get it working?
Old Mar 31, 2019 | 10:17 AM
yardbird's Avatar
All of the electrical issues I was having are now fixed. I brought the truck over to the shop and showed them where the short was and we agreed that going at the short from below was the way to go. Some people won't agree with what I told him to do but taking a cut-off wheel he cut a 10X15 inch hole in the fender skirt to access the harness. He unwrapped the harness and found 9 burnt and damaged wires. He told me that he extended, soldered and shrink wrapped 7 of the wires and butt connected the other 2. Yesterday I took a 12X18 piece of sheet aluminum and a tube of J.B. Weld sealer and patched up the hole in the skirt. He charged me 200.00 for the repair. I spent another 20.00 for the supplies. I like to call that the cost of aggravation.
Thanks to all who contributed to this thread. Your input gave me the confidence to search out this pain in the pass.
That's all for know. I'll be back soon seeing I own a Blazer.
Old Mar 31, 2019 | 11:44 AM
cleburne red's Avatar
Really glad you got it fixed! Sucks to pay so much, but I bet you're relieved to have it done!
Old Mar 31, 2019 | 07:24 PM
Always good to hear another problem fixed
Banjo boy john
Jan 16, 2016 11:28 AM
Brother Marc
Jul 5, 2013 09:39 PM
camaro60181
Mar 12, 2009 09:49 AM
jamon8
Mar 10, 2008 06:50 AM
