Lowering Tech This section is for suspension questions related to decreasing the ride height of your vehicle.
Almost ready to drop 2000 Chevy blazer...Anything else???
Old Sep 28, 2013 | 09:05 AM
TORDIS713's Avatar
TORDIS713 is on a distinguished road
Default Almost ready to drop 2000 Chevy blazer...Anything else???
I have a 2000 chevy blazer 4 door 2wd can i simply install 2 inch drop spindles up front and 3 inch lowering blocks in rear and call it a day??I hear on other forums that setback plates and pinion shims are needed as well to do a drop..Are they necessary or can I just go with my setup..If anyone's dropped their blazer with just spindles and blocks please let me know.
Old Sep 28, 2013 | 10:39 AM
chris015's Avatar
ive done it. never had an issue. but pinion angles can be a problem. Just drop it,if you feel any vibrations on the highway then look into shimming your rear end.
Old Sep 30, 2013 | 10:56 PM
kajida's Avatar
kajida is on a distinguished road
I had 4 inch drop blocks in the rear that were angle cut, no need for the shims, and got a slight vibration. I swapped to 3 inch blocks that weren't angled and the vibration is gone. I stuck an angle finder on my driveshaft and the axle input and i'm running a 3 degree angle, which is about where it needs to be. So yeah, just gotta slap it in and see where you are at imo. Depends on tire size and all that good stuff.
Blue thunder 2000
Aug 20, 2012 10:45 PM
rdlyn
Engine & Internal
May 7, 2010 05:23 AM
9t54x4
Mar 1, 2010 04:06 PM
lizardqing
Nov 21, 2009 03:30 PM
Taymacjack
Engine & Internal
Aug 28, 2007 07:58 PM
