Cragar Quarstions
Old Oct 26, 2009 | 08:54 PM
Originally Posted by Sisk
Spacers are legal yes...
They don't seem to make a Cragar in a 6in backspacing. I took a loo through those pages and didn't see anything above 4.25in.
http://www.summitracing.com/parts/CRR-3975734P/
Those would work. You might have to get some spacers though to have them fit properly. It would probably take some playing with the spacer size..but I'll wait for someone else to pipe in and confirm this for sure since I've never actually researched it much myself.
I just know the stock backspacing on a 4x4 rim is 6in.
Spacers do not increase backspacing. They decrease it. You cannot increase the backspacing on a rim without moving the wheel mounting surface further towards the outside of the rim.
Old Oct 26, 2009 | 11:27 PM
ABN31B's Avatar
check in the wheels and tires section. there is a lot on various sized rims, tires, lift, lowering, back space, rub, spacers... etc
most of it has been asked and answered. get friendly with your search function.
Old Oct 27, 2009 | 06:48 AM
CraigSnedeker's Avatar
Alright thanks this area is new so before I'd buy (which isn't any time soon anyway) I'd want to know exactly what to expect ya know?
Old Nov 14, 2009 | 06:04 PM
Alright so my dad told me he wants to get new rims for the winter tires and told me if I wanted anything I'd have to pay the difference. He was going to get some stocks but I told him I had some in mind.
Now you told me the bolt pattern and everything I need but question: Will it fit without question on a 4wd? I think the tires he's getting are the same size as stock so I won't worry there. I just need to know
Old Nov 15, 2009 | 05:40 AM
Sisk's Avatar
...As Curtis mentioned above you need to start getting friendly with the search feature. Cragar's are probably the most discussed rim on the forum. A little searching would have found your answer...
Post #4 of https://blazerforum.com/forum/tires-wheels-13/just-looking-some-help-36836/
More posts of relevance:
https://blazerforum.com/forum/tires-wheels-13/couple-questions-35070/
https://blazerforum.com/forum/tires-wheels-13/tires-rims-35011/
https://blazerforum.com/forum/tires-wheels-13/cragar-size-34716/
https://blazerforum.com/forum/tires-wheels-13/another-will-these-rims-fit-thread-32972/
https://blazerforum.com/forum/tires-wheels-13/new-wheels-31987/
And I could go on but I think 6 threads should be enough to answer your question....All I did was search Cragar. Here are all the results if you'd like to browse through them:
https://blazerforum.com/forum/search...earchid=328207
Old Nov 15, 2009 | 07:10 AM
old skool luvr's Avatar
Kyle is right. spacers will affect the off-set of the rim, causing it to stick out farther, which is what you're after right?
Old Nov 15, 2009 | 10:35 AM
Sisk's Avatar
Yeah I get what Kyle was saying now that I think about it. I'm not sure why I thought spacers would help. It worked out in my head that night I posted it for some reason LOL. Maybe I had had a few too many beers...
Old Nov 15, 2009 | 12:23 PM
oktain's Avatar
As it is though, they'll be sticking out an extra 2 inches, and 2 much makes a stock height truck look like a wannabe go-kart. I say buy the rims, and if you want them to stick out more, get spacers. Don't buy the spacers before the rims because you may not even want to use them... The easiest way I can explainbackspacing to you craig is with this:
It's the distance between the mounting surface and the inside lip of the rim... On 4x4's it's 6 inches, if you get a rim with 4 inch backspacing, that mounting surface will be 2 inches closer to the inside lip, pushing the entire rim out 2 inches... Once you wrap your head around the concept you'll see it isn't that complicated, it's actually visualizing it that's the hard part.
Old Nov 16, 2009 | 07:53 AM
Sisk: I had tried and didn't really find anyting
Old: Not really but it would be cool
Oktain: So your saying they'll fit, but will stick out a little bit? What about the fronts?
Old Nov 16, 2009 | 08:25 AM
Sisk's Avatar
You have been told the answer over and over Craig.
THEY WILL FIT. But they will stick out an extra 2" compared to the rims you have on them now. This was all answered in the 6 LINKS AND A SEARCH I posted for you as well as by Pat.
Sorry for yelling, but I'm getting extremely frustrated because you're given answers over and over but you don't care to read or listen and continue to ask the same questions over and over again.
bigjon1
Lifting Tech
Jan 30, 2010 06:39 PM
appstateblazer
Tires and Wheels
Jan 12, 2010 10:37 PM
jfosc11
Tires and Wheels
Sep 16, 2009 09:26 PM
99Jimmster
Tires and Wheels
Aug 20, 2009 08:51 PM
Kingswede
Tires and Wheels
24
Aug 14, 2008 12:07 PM
