Rear bumper lift
Old Oct 31, 2020 | 03:23 PM
Hadyss's Avatar
Default Rear bumper lift
So I’ve tried looking and haven’t found any clear answer. I have a 2000 blazer 4dr and I’ve put a body lift on it but my rear bumper can’t be lifted with the body as I have the factory tow package. I’m wondering if anyone has found a way to lift the bumper and how they did it
Old Oct 31, 2020 | 04:19 PM
What kit did you get? The one I was looking at doesnt say anything about factory towing, but says the bumper cant be used for towing, which I wouldnt do anyways lol...
Old Oct 31, 2020 | 04:27 PM
Hadyss's Avatar
That is the kit I got but if you have the factory tow package then u can’t use the brackets they included for mounting the rear bumper. The tow package has the brackets on the hidden hitch and non tow package has mounts that u replace with the kit
Old Oct 31, 2020 | 04:28 PM
Hadyss's Avatar
The bumper brackets are the outside brackets in the picture u posted and I ordered it from summit was cheaper and quicker shipping
Old Oct 31, 2020 | 06:37 PM
Can you cut the stock bumper brackets and weld them back together with an offset so the bumper sits up higher? I did that once on a full-size Chevy and it worked pretty well.
Old Oct 31, 2020 | 07:10 PM
Hadyss's Avatar
I was tempted to look and see if I can cut the stock and bolt the new brackets on with the hitch still
Old Nov 1, 2020 | 08:48 AM
With a torch and a welder, all things are possible.
Old Nov 1, 2020 | 11:14 AM
Hadyss's Avatar
I have a grinder and lots of discs and lots of welder wire for my welder so ya
Old Nov 23, 2020 | 09:46 PM
Hadyss's Avatar
So I got the bumper all lined up with the performance accessories bumper brackets I posted it all on my build and the steps with pictures on how I did it mostly cutting but the top bolt holes on the bumper had to be drilled out a little more to get the bolts to line up but that’s simple
https://blazerforum.com/forum/builds...-95423/page10/
hypedave
Lifting Tech
Dec 15, 2013 03:32 PM
goldie
Aug 11, 2010 09:49 AM
Viperguy
Lifting Tech
Dec 15, 2009 10:43 AM
matthew.chapman1
Lifting Tech
Aug 12, 2009 08:16 PM
S10Blazer
Oct 9, 2006 11:45 PM
