roof rack
Old Feb 12, 2010 | 09:08 PM
jaybird33081's Avatar
jaybird33081 is on a distinguished road
Default roof rack
ok guys, i have a 97 4dr. i have no roof rack and i want one lol. is it possible to add one? if so how much work is it?
Old Feb 12, 2010 | 10:41 PM
Spectreblazer's Avatar
Banned
Spectreblazer is on a distinguished road
yup junkyard special
Old Feb 13, 2010 | 10:07 AM
ABN31B's Avatar
roof rack is 2 bolts at each of the 4 posts for 8 bolts total install. make sure you NEVER had one (the factory one wan't pulled an dthe holes filled) and get to work.
you you had one, drill into the old holes and but and appropriate thread chaser in to clean up the old holes. drop the new rack on and win.
if you never had one, i really dont know.... i would:
take out my head liner, and put sheets or drop cloth over my seats. take the donor rack i wanted to instal, and trace the feet where it would sit on the roof to a pice of wood, card board, or paper. i would then drop the rack on the roof and line it up where i want it. drill in 8 pilot holes, move the rack and drill the holes to the right dia. I would take my tracing and use it as a template to cut 4 inside aluminum mounting brackets then drill the holes in. have a buddy hold them inplace and bolt the roof rack on after quadruple checking that each leg still had the weather seal!!! after it was bolted down i would probably seal the bolts with silicone because i would worry more than is necessary. lastly i would re-install my headliner and win.
BUT all of that comes from my lack experience with "no factory rack" SUVs. That is how we did my brother's '90 cherokee and it had heald like a champ. looking back, you may want to do a long run of aluminum to get more surface area (ie one down the d side one down the p side OR one across the front and one at the rear to spread the load on the roof better...
chances are some one with proper Blazer experience will chime in and tell me how wrong that was
Old Feb 13, 2010 | 05:07 PM
Banned
make sure to use short self tapping screws, wouldn't want them sticking through the headliner
CPLSeraphim
May 20, 2014 05:48 PM
RobRad
Mar 24, 2014 06:08 PM
davtak
Jan 10, 2007 04:33 PM
haloboy99
Apr 25, 2006 07:13 PM
timetoblaze
Nov 16, 2005 01:08 AM
