awd to 2wd
Old Mar 9, 2010 | 07:35 PM
ajfalco's Avatar
ajfalco is on a distinguished road
Default awd to 2wd
i have a 1996 4dr blazer awd the front diff toasted. i don't have money to fix right now. so i removed the front diff , halfshafts and the drive shaft to the transfer case. will the trasfer case be alright with no front driveshaft and do i need to leave the front part of the halfshaft in the hub to keep the bearings tight.
Old Mar 9, 2010 | 07:49 PM
If it was a true AWD truck (ie not selectable 4wd), then no, your transfer case will not be good without the front drivetrain. It is a viscous coupling transfer case which sends ~30/70 torque split front/rear.
And you should leave the stub shafts in the front bearings to keep things proper in that regard.
99blklt4wd
Oct 8, 2014 11:18 AM
98BravadaST
Jan 16, 2010 12:35 PM
TripleBlackBlazer
Lowering Tech
17
Jan 12, 2008 10:46 PM
felonyblazer96
Dec 4, 2007 11:05 AM
Jnike120
Dec 5, 2005 06:47 PM
