Camber issue
Old Sep 14, 2009 | 01:32 PM
dimone545's Avatar
dimone545 is an unknown quantity at this point
Default Camber issue
Well I finally found the time to install the front portion of my trailmaster lift and when I set it back on the ground with the stock tires on it the camber is messed up? The driver side is pretty good but maybe has a little posi camber but the passenger side has a very noticeable neg camber. How in the hell do i fix this? Is this something that has to do with the tie rods when doing an alignment? Or could there be something wrong with the lift kit? Any help will be appreciated.
Attached Thumbnails Camber issue-blazer-front-end-short-distance.jpg   Camber issue-blazer-front-end-passenger-close-up.jpg   Camber issue-blazer-front-end.jpg
Old Sep 14, 2009 | 01:49 PM
bandidolenny's Avatar
You probably need to adjust the top camber bolts all the way out like I did mine.
If that's not enough then you will need aftermarket cam bolt washers with extra cam adjustment built into them.
Old Sep 14, 2009 | 01:50 PM
AJBert's Avatar
I wouldn't worry too much about it right now. Just get an alignment done when you finished every and you'll be good to go.
shotnva777
Aug 11, 2011 05:41 AM
yanick27
Tires and Wheels
Apr 10, 2011 10:18 AM
USMarine1108
Oct 18, 2009 09:47 PM
stevelknievel
Suspension Tech
Jun 23, 2009 05:05 PM
AK8BLANK
Suspension Tech
Mar 3, 2007 07:55 PM
