How Hard would it be to change leaf springs?
Old May 7, 2009 | 09:28 AM
  #21
Damn... Well that sucks. If that is the case, then you will have to loosen the gas tank and move it.
Old May 7, 2009 | 09:37 AM
  #22
rubeninfl's Avatar
rubeninfl is an unknown quantity at this point
Should the nut be on the outside? or should the nut be on the inside? I can cut the bolt and get it out...I have 2 new ones, but if I do that, I'm going to have to put the bolt in opposite of the way it's in there now....meaning that I have to put it in from the outside, and the nut will be between the bolt and gas tank. I can't imagine that this would make a difference, but If I don't do that, I will definitely have to remove the gas tank.
Old May 7, 2009 | 09:51 AM
  #23
mr.vls's Avatar
If the thread protrusion of the bolt would not hit anything I would cut the head of the bolt off to remove it and then reverse the installation.
Old May 7, 2009 | 09:58 AM
  #24
Damn good idea. Get the new bolts first! Grade 8 only. Just measure up the originals and run down to your nearest farm supply store and they should have what you need.
Old May 7, 2009 | 12:59 PM
  #25
rubeninfl's Avatar
Okay...on to the next problem. I've got the spring out....bolts out.. Now I've put the new spring in place. I was able to put in the front bolt....putting it in so the nut is on the gas tank side. Then I raised the rear end of the spring to put the rear bolt in and it comes up about 2 inches short of the holes lining up. This is the correct leaf spring because i lined it up with the old one and they are exactly the same size. Obviously the holes will line up once there's some tension and it stretches out a bit. Maybe I'm putting this back together incorrectly? I was going to put the front and end bolts in first...and then get to the U-bolts. Is this wrong? Do I have to do the u-bolts first? I have to be doing something wrong here.
S10Blazerdude
Lowering Tech
May 1, 2010 07:56 PM
blazerJim1701
Aug 9, 2009 10:32 AM
alamantia
Suspension Tech
Nov 17, 2006 11:14 AM
tommyd
Suspension Tech
Aug 25, 2006 12:11 AM
4lowlife
Suspension Tech
Mar 8, 2006 03:53 PM
