how to put my leafs on top of the rear axle
Old Apr 26, 2011 | 08:20 PM
luckyferg1313's Avatar
luckyferg1313 is on a distinguished road
Default how to put my leafs on top of the rear axle
how do i make my truck a leaf over axle i've looked all over the place and i can't find any good info on the subject. PLEASE HELP ME! i'm in desperate need of help none of my friends know how to do this
Old Apr 26, 2011 | 10:48 PM
Benedict1337's Avatar
I believe the superlift 6" and bds 5" lifts have the leaf over axle swap kit with them. I know you'd need longer brake lines, probably new u-bolts, and some way to lengthen the swaybar end links
Old Apr 27, 2011 | 09:49 AM
i have no rear or front sway bar so i can flex when i need to. also it made my ride alot smoother. i'm just looking for a junkyard way to do this.
Old Apr 27, 2011 | 10:51 AM
you know you will have one big rake if you do an axle flip, even with the torsion bars cranked the whole way your rear will sit a lot higher than than the front. I would say if you are trying to just do it get some new u-joints and make your brake lines a little longer thats all that really needs to be done. and ride smoother? I wouldn't say that with the sway bars, with the front one off, its scary on the highway
Old Apr 27, 2011 | 11:53 AM
abig84's Avatar
If its just a offroad truck you don't even need to get a longer brake hose. I just made a bracket to extend it up. Looks horrible but will work. As was said just cut the u bolts off and relocate the axle. You may need to round off the head of the bolts on the spring pins so the axle hole on the perch will slide over it
Old Apr 27, 2011 | 02:50 PM
zr2dan's Avatar
zr2dan is on a distinguished road
your stock shocks may not handle the swap either you will have get new ones or relocate shock mounts or fab up some shock mount extensions
Old Apr 28, 2011 | 09:46 AM
well found out one of my stock shocks is already busted. yes back in 88 on certain submodels they had bilstien shocks on the truck. but im also looking for a way to lift the front "junkyard" style. and i have drove over 80 on the highway with no front sway bar and it handled fine btw this is my DD. thanks for all the advice guys
Old Apr 28, 2011 | 10:57 AM
abig84's Avatar
If you wanna be true junkyard style. Cut your fenders off. I fit 35s on a 85 I had. There's no real way to. Lift the front end. High enough to match the soa rear
jake kick
Apr 27, 2013 01:25 PM
street101
Oct 29, 2010 04:17 AM
tattoo_cyrus
Lowering Tech
Oct 15, 2008 12:37 PM
rickyp3278
Suspension Tech
Mar 26, 2008 11:03 PM
90blazinchevy
Oct 5, 2007 01:52 PM
