Leaf Springs
Old Mar 1, 2017 | 02:04 PM
Electechab's Avatar
Electechab is on a distinguished road
Default Leaf Springs
I am replacing the rear axle on a 2001 Chevy Blazer. The problem I am running into is when I put the axle in the spot where I took the old one off, it is too far to the rear. I see the back of the leaf springs are bolted to a bracket which bolts to the frame. Is it possible that when the differential locked up the brackets moved?
Old Mar 1, 2017 | 04:19 PM
chevyriders's Avatar
I doubt that they'd move. It bolts into a pocket on the frame I'm the front also, so your leafs can't really move back at all unless you sheared your centerpins.
Did you take the leafsprings off? I believe they are shorter on one side than the other. They could be backwards
Old May 1, 2017 | 09:53 PM
RTJ49's Avatar
RTJ49 is on a distinguished road
The bracket you are talking about, do you mean the shackle? If so, they do move. When I changed my leaf springs the bottom bolt on the shackle had to be moved as far back as possible to get the leaf spring centering pin to align with the mount plate on the axle housing. I used a floor jack to move the spring up and get the shackle to move/angle more to the rear, then a little force on the axle housing, pushing it forward, and it dropped in place. I hope this helps.
Old May 2, 2017 | 04:06 AM
newguy's Avatar
Is it the correct axle? Are the wheels to far back or is it that the driveshaft wont reach. The axle carrier could be shorter
S10Blazerdude
Lowering Tech
May 1, 2010 07:56 PM
2Tone
Mar 29, 2007 12:20 AM
alamantia
Suspension Tech
Nov 17, 2006 11:14 AM
tommyd
Suspension Tech
Aug 25, 2006 12:11 AM
4lowlife
Suspension Tech
Mar 8, 2006 03:53 PM
