Pop when in reverse and Squeaks over bumps HELP!
Old Nov 1, 2011 | 03:43 PM
AKPerry's Avatar
AKPerry is on a distinguished road
Default Pop when in reverse and Squeaks over bumps HELP!
Hey guys I have a 1999 S10 Blazer, 2dr, 4x4. The past week i've noticed when i go into reverse to leave in the morning, theres a slight "pop" from the front drivers side wheel. and when driving, even over the slightest bump, i get a high pitched squeaking sound. ive been searching allll over the forum and on the internet trying to determine the problem. I just replaced the hub assembly on BOTH sides within the last 2 months. Could it be bad Shocks? Tie-Rods? Im a bit of a newbie at working on cars but i know my blazer inside and out. ANY help is appreciated!
-Anthony
Old Nov 2, 2011 | 10:24 AM
cbr995's Avatar
From what I know, its typically the ball joints that do it. Mine does it as does seemingly every Blazer lol. I haven't investigated it but I have new lower ball joints so I guess the upper ball joints are the culprit. Although it doesn't hurt to replace the tie rods, too.
Old Nov 3, 2011 | 12:40 AM
chevybaby's Avatar
chevybaby is on a distinguished road
Or could be bushings rather than balljoints. Mine started squeaking about a month or two ago. And I just replaced the balljoints in May. Just got the money to have it checked out and it ended up the bushings were trashed.
-Katie
Old Nov 3, 2011 | 09:55 AM
AKPerry's Avatar
Thanks for your input guys, i checked everything you said but I think its gonna end up being the shock bushings! so ordered new shocks and hoping that will do it. if not i dont know what ill do!
Old Nov 3, 2011 | 11:28 AM
cbr995's Avatar
Well here's to hoping that's all it is. As long as you can avoid having to drill out the ball joints.
Old Nov 3, 2011 | 11:38 AM
chris015's Avatar
Might be the top left control arm bushing. I forgot to tighten the bolt for it on mine,and mine popped in reverse the same way. Tighten your bolts and make sure its ok.
mdabbs
Jul 15, 2015 08:19 PM
lionel2
Aug 31, 2012 09:26 PM
Chevyboy28
Jun 11, 2009 02:06 PM
BrokenBlazr
Feb 26, 2009 08:16 PM
Nick Bain
Feb 25, 2009 03:58 PM
