Suspension Tech Have a question about modifying your suspension? Ask it here.
How much can a 2001 Blazer LT Tow?
Old May 24, 2009 | 07:39 AM
blazerJim1701's Avatar
blazerJim1701 is an unknown quantity at this point
Default How much can a 2001 Blazer LT Tow?
If I lose my job I will be forced to move down to Florida from NJ, I would like to take as much as I can, Ex Sofa, kitchen table and such.
I've heard that it can pull 1K lbs...
I'd be pulling a uhaul.
Thanks
Jim
Old May 24, 2009 | 08:35 AM
BIGred4X4's Avatar
BIGred4X4 is on a distinguished road
Default tow
if u got a hitch bout 9k lbs no hitch like me bout 3to 4k thats all at the max
Old May 24, 2009 | 09:14 AM
rriddle3's Avatar
Here's what the owner's manual says:
Attached Thumbnails How much can a 2001 Blazer LT Tow?-tow.gif   How much can a 2001 Blazer LT Tow?-tow2.gif
Old May 24, 2009 | 10:45 AM
Sisk's Avatar
It depends on where your hitch is too. Mine is the stock one...that ball on the bumper itself. If you get one installed underneath to the frame you will be able to haul more.
Old May 24, 2009 | 11:57 AM
rriddle3's Avatar
You still should not exceed the weights from the manual. Those are maximum. If you are using just a bumper hitch ball, you have to stick with the limits stamped on the bumper.
Old May 24, 2009 | 01:43 PM
okvortec's Avatar
You should definitley consider getting an actual tow hitch installed. I'd try not to use the bumper ball..
(On a side note, people are always talkin about "what's a 2WD truck good for?' Or "if I wanted 2WD I'd have gotten a car." Well mine, a 2dr 2wd can tow the MOST of anything listed in that manual. )
Just thought that'd I point that out
Old May 24, 2009 | 10:20 PM
86Blazer4x4's Avatar
86Blazer4x4 is an unknown quantity at this point
where would i be able to find out how much my blazer tows? i have a 86 4x4 two door automatic with 4.11 gear ratio with the 2.8L V6?
Old May 24, 2009 | 11:14 PM
mech cb's Avatar
mech cb is on a distinguished road
I refuse to put anything more than body weight on my bumper. I've seen WAY too many fail.
As far as the two wheel thing, my Blazer hasn't met any condition that wouldnt be an absolute mess to clean up after that it couldnt handle. The one mudhole I did attempt, it took 9 hrs of cleaning to get it how I wanted. I'm good with just 2wd.
Old May 25, 2009 | 08:19 AM
Sisk's Avatar
Agreed. If you're planning on doing a decent amount of towing, it's probably best to invest in an on-frame hitch. It will save you in the long run, plus you'll be able to tow more!
Old Jul 6, 2009 | 09:32 PM
I know with u-haul you can rent the hitch that they install. Then they remove it. I don't want to tow after that.. As every one can tell I don't tow anything with it except for this time with moving to Fl.
Thanks
Jim
BluBlazerKid
Performance & Brainstorming
Apr 12, 2015 03:54 PM
Tenagator
Jan 22, 2014 06:04 PM
Doctorvette
Nov 5, 2012 11:57 PM
mattjphoto
May 31, 2011 10:16 AM
