Suspension Tech Have a question about modifying your suspension? Ask it here.
Shackle Question
Old Jun 12, 2010 | 09:28 PM
Lumpo's Avatar
Lumpo is on a distinguished road
Default Shackle Question
I just got done installing my homemade shackles and i went 3.5" more bolt to bolt and i would really like to go more if i could because im still getting a little sag. How much higher can i go with them safely? How much further apart are the 2" shackles you would buy already made than the stock shackles?
Old Jun 12, 2010 | 09:45 PM
Lumpo's Avatar
Ok so i was doing alittle bit of research and found i actually only raised my truck 1.75" with my 3.5" longer than stock shackle. So that being said i should be able to go up to at least 6" longer than stock seeing how guys are running 3" shackles correct?
Old Jun 12, 2010 | 09:46 PM
ImScrewed92's Avatar
If your asking about how long of a shackle you can run, you should check your local vehicle inspection laws. IE in WV, you "legally" can't run any shackle longer than 2 inches over stock shackle lenth. So if your area is really **** about inspections, talk to somebody that knows the law first.
Now, that the "legal" disclaimer is out of the way, on to real talk . You can buy three inch lift shackles from 3leaffab on ebay. They are a whopping six, yeah SIX inches long. There is a member on here with a ZR2 blazer that runs them,
"Blazerguy2001" is his forum name. Look up his build thread and see what you think about them.
Not saying you have to buy those shackles. But if your making your own, you could get an idea of what other people have ran safely.
Yeah your right. Where you're only adjusting the rear of the leaf springs and not the front, you get half the lift. IE 3 inch longer than factory shackle= 1.5 inch lift. 6 inch longer than factory shackle=3 inch lift.
Old Jun 13, 2010 | 04:33 PM
Lumpo's Avatar
Ok good because i got a little disappointed after i installed my shackles thinking i went 3.5" taller than stock and still seeing the rear sagging. When i made my shackles i also drilled 2 extra holes incase i ran into to this problem so ill just have to unbolt the bottom and switch holes so it should be 1, 2, 3.
Old Jun 13, 2010 | 08:37 PM
Yeah, alot of people don't think about the whole 1/2 lift thing. Good thing you pre drilled the holes on the shackles. That way you don't have to try to drill them while still on the blazer or have to take them off. You oughta post some pics when you get done, if you get a chance or have a camera.
Old Jun 14, 2010 | 11:42 AM
Lumpo's Avatar
Sure thing i plan on it.
Old Jun 16, 2010 | 08:21 AM
king's Avatar
king is on a distinguished road
Question
i plan on doing the same thing,do u know the size of the bolts? i want to buy them before i start.
Old Jun 17, 2010 | 12:54 PM
Lumpo's Avatar
I believe there 3/4 but im not 100% sure.
FIVEHORSE
Lifting Tech
Mar 17, 2013 01:46 AM
Monkeyman
Nov 11, 2009 04:20 PM
Monkeyman
Lifting Tech
Nov 7, 2009 05:03 PM
nyzr21019
Lifting Tech
Nov 6, 2009 08:22 PM
99blaz
Jul 24, 2008 08:33 PM
