putting rims on blazer
Old Feb 16, 2010 | 10:19 PM
ryankinder82's Avatar
ryankinder82 is on a distinguished road
Default putting rims on blazer
i got a set of 22x9.5 inch rims. the tires are 265/35's. they are going on a 1998 4x4. i know i will have to crank the torsion bars up for clearance but will i have to get an alignment done once i do turn the torsion bars. will it create toe in or toe out. i dont want to wear the tires down on only one side.
Old Feb 16, 2010 | 10:23 PM
NVANZEE's Avatar
yes you will need to get an alignment
Old Feb 16, 2010 | 11:50 PM
packofqtips's Avatar
packofqtips is an unknown quantity at this point
it will actually create positive camber and yes you will need an alignment
Old Feb 17, 2010 | 08:44 AM
Sisk's Avatar
x3. Anytime you touch the tbars you need an alignment. It throws the front end all out of wack.
Old Feb 17, 2010 | 09:45 AM
Unlimitedsp's Avatar
Yes you will need an alignment. but the 22's shouldnt have any clearance issues. I ran 22's on stock height without any issues. Those wheels and tires will only be a tad taller then stock. Stock diameter is 28.9" new tire is 29.3". Thats a differance of only 0.4". You should be fine.
Old Feb 17, 2010 | 05:23 PM
i put them on last night and they rubbed on the bottom of the fender. i take it its probally because of the +13 offset. they only stick out like a half in though up front
Old Feb 18, 2010 | 12:00 AM
old skool luvr's Avatar
since we don't know the mileage of your truck, i'm gonna guess maybe the t-bars sag a bit? but if you crank the bars (even an inch), you're gonna need to bring the rear up too.
have you checked your wheel wells to see if you're sitting level?
Old Feb 18, 2010 | 12:07 AM
usually these trucks sit an inch higher in the rear so cranking up the bars will most likely just level the truck out
819RIG
Tires and Wheels
Nov 29, 2009 10:45 PM
sasquatchfound
May 13, 2009 03:25 AM
in2classx
Sep 4, 2008 10:56 AM
98chevyrider
Nitrous, Super Chargers, & Turbos
Jun 21, 2008 08:49 AM
lafd55
Mar 30, 2007 09:11 PM
