What 15x8 rims to use w/ how much backspacing?
Old Jan 28, 2019 | 11:07 PM
biggermrbrute's Avatar
biggermrbrute is on a distinguished road
Default What 15x8 rims to use w/ how much backspacing?
Alright guys so, I’ve got a ‘00 4 door 4x4, G80 (locker) rear end w/ 3.42 gears, and just the standard/stock diff up front. I have the STOCK torsion keys cranked a little over 3/4 of the way up (not great, I know) but I’ve checked the CV angles and they don’t look bad at all, hardly much angle at all if we’re being honest so if I HAD to I could crank it up a little more or maybe put aftermarket keys in but I’d rather not do that. In the rear, I have lift shackles and air shocks (with that combo, I can lift the rear ATLEAST 2.5-4” above stock height) I’m wanting to put a set of Cooper STT Pro (32x11.50r15) on it. I was going to put a 2” body lift on it as well (made by performance accessories). But I’m waiting to do the body lift to see what size tires I can put under it, as I only have 235/75r15s at the moment so raising it any higher would just make it look silly lol. whatcha guys think? Would I be able to clear those 32x11.50r15 with the current suspension setup I have on top of a 2” body lift? And for wheels, I’m aware they need to be spaced out farther than stock so they won’t rub as much/at all on turns on the inside. How much would they need to be spaced out? What backspacing would I need on the wheel or wheel spacers? Thanks!
Old Jan 29, 2019 | 04:53 AM
cleburne red's Avatar
I have a set of 15x8, with 4.5" backspacing, and there's enough room to clear a 10.50" tire at full lock. You might could get away with 11.50", but it's going to be pretty close to the frame and sway bar at full lock.
You could run with less backspacing, and have room for the bigger tire, but you'll run into issues with the fender, if you don't have enough lift
For reference, I'm running 33x10.50 on a 6" suspension lift
clw97bravada
Lifting Tech
Jul 3, 2010 02:28 AM
ldzisme
Lifting Tech
Mar 20, 2010 11:35 PM
Gambler28
Lifting Tech
Mar 5, 2010 07:22 PM
robbiegamble
Suspension Tech
Aug 24, 2008 09:42 PM
GimmieBoost
Suspension Tech
Apr 5, 2008 02:26 PM
