Little Insight on my 4.3 vortec problem
Old Nov 23, 2009 | 12:18 PM
Vexxx1708's Avatar
Vexxx1708 is on a distinguished road
Sorry about that it's getting 60-62psi, and actualy im purchasing that today (the harness).
If this is off topic just let me know but I was told that the distributor controls the firing of the injector because the computer gets the timing to fire it from the distributor.
Old Nov 23, 2009 | 12:25 PM
The injector timing is controlled in part by the CKP (crankshaft position) sensor adn in part by the CMP (camshaft position) sensor. Both sensors are used to determine the precise timing for the injector to fire. The CKP is located in the timing cover on the front of the engine while the CMP sensor is located inside the distributor.
Old Nov 23, 2009 | 12:47 PM
Vexxx1708's Avatar
Ok, thank you. Will post back when I get the harness on.
Old Nov 23, 2009 | 09:53 PM
NC93BLAZERLT's Avatar
NC93BLAZERLT is an unknown quantity at this point
EGR valve anyone? Checked it? Cleaned it? Blew it out yet? That could cause some of the symptoms you mentioned. I wouldn't buy a new harness until all avenues were checked. Unless you got it like that. Just a suggestion.
95jimmy_slt
Mar 11, 2013 12:52 PM
ZaBlazer99
Sep 1, 2012 06:44 PM
0Blzr4door3
Jun 18, 2011 04:53 PM
amart
Nov 5, 2010 08:34 PM
BradensCreed
Aug 2, 2007 11:15 PM
