Plugs & Coil replacement
Old 06-05-2011 | 08:57 AM
JerryB52's Avatar
JerryB52 is on a distinguished road
Unhappy
Okay, fuel pressure went to 50 psi when I cranked it over, then within 5 to 10 seconds, dropped to nothing...
It's the regulator and nut kit, right?
  #22
Old 06-05-2011 | 09:09 AM
Leeann_Bravada's Avatar
Leeann_Bravada is an unknown quantity at this point
It could either be the fuel pressure regulator, the check valve in the fuel pump or the little piece of hose connecting the pump to the hanger assembly.
  #23
Old 06-05-2011 | 09:27 AM
hubert hefner's Avatar
hubert hefner is on a distinguished road
pull the plenum off and turn the key on and you will see the leak. the plenum is easy to get off. alot of times the lines get a hole in them or the FPR goes bad.
  #24
Old 06-05-2011 | 11:20 AM
chris015's Avatar
chris015 has a spectacular aura aboutchris015 has a spectacular aura aboutchris015 has a spectacular aura about
Yes
The check valves are usually pretty good with these pumps. This problem he is having is 99% of the time is the regulator or nut kit in these certain vehicles. It could still be the check valve etc but i highly doubt it.
JavierEscalonJr
10-14-2020 11:38 PM
jkyle187
02-15-2015 08:45 PM
blainenbecky
03-09-2013 10:38 PM
Lancealot
02-22-2011 07:34 AM
skoot61
02-19-2008 11:20 AM
Quick Reply: Plugs & Coil replacement
