1995 ideling problem
Old Jul 21, 2011 | 11:21 AM
  #31
SlickBlazer's Avatar
SlickBlazer is on a distinguished road
ok i can hear the leak just dont see it i will go out and look the whole system over and see if i can fine any leak and fix it then will see how it is
Old Jul 25, 2011 | 04:36 PM
  #32
ok i have check the whole exhaust system out and fixed the leak i found no change in the idling problem so i pulled the spark plugs out one at a time check gap and i did notice that other then carbon up bit they were all wet with gas i think
Old Aug 11, 2011 | 08:21 AM
  #33
Unhappy Still idleing problems
Yesterday i checked all the plugs and gaps all good started it it idled fine till at operating temp then it died and hardly idled this morning i tried to start it it started but wont idle , and it is running rich i think from the black smoke that comes from the tail pipe what could be causing the problem
Old Aug 11, 2011 | 08:39 AM
  #34
Have you tested the MAP sensor? Search for "MAP+voltage+altitude" with an author of "swartlkk" and you should find the relevant results.
Old Aug 11, 2011 | 08:54 AM
  #35
i tryed looking for it could not find it does it explain how to test the MAP also
Old Aug 11, 2011 | 09:23 AM
  #36
pettyfog's Avatar
It's here:
https://blazerforum.com/forum/2nd-ge...-crappy-51103/
Old Aug 11, 2011 | 09:24 AM
  #37
thanks i will test it and see what happens
Old Aug 29, 2011 | 11:08 AM
  #38
i have tested the map it seems to be ok i was rechecking the fuel system and found a small fuel leak on a line it did not sell of fuel or drip but i did check and it was fuel would that mall leak cause all this problem ? I did not see the leak at first a friend found it while helping me
Old Oct 3, 2011 | 02:20 PM
  #39
I have fixed the fuel leak it spit a bit and died at first but then ran for 1 hr before dieing again it spit and sputtered then died and other ideas
Eman5pt0
Jun 8, 2009 04:12 PM
daj
Feb 13, 2009 05:04 PM
doubleuap
Nov 10, 2008 12:34 PM
xckid
Oct 15, 2008 05:58 PM
kpiper
Dec 15, 2007 06:28 PM
