Starting trouble
Old May 19, 2011 | 11:45 AM
Burnboy's Avatar
Burnboy is on a distinguished road
Default Starting trouble
I have an 03 s10 2.2 5spd. My truck wouldn't start a few weeks ago out of the blue. I turn the key and nothing, no clicking or turning over. Lights come on and fuel pump primes. I can push start it. Here is what I have done so far.
Starter bench tested fine
Replaced ignition switch
I am getting power to the crank fuse
Battery is fine
Tried new clutch switch
Cable from battery to Starter is fine
Jumped the starter and it spins fine
Swapped out starter relays.
What is my next step? I am at a loss here. Thanks for any help.
Also my engine bay makes a strange ticking noise, sounds like it is coming from the injectors or throttle body, here is a video, it happens randomly when I leave the key in it. its kind of faint
YouTube - ‪Ticking noise‬‏
Old May 19, 2011 | 11:57 AM
Burnboy's Avatar
Just checked voltage at the small terminal of the starter. My battery is getting a bit low but my battery reads 11.3 volts and the small terminal at the starter reads 9.85v
Old May 19, 2011 | 04:11 PM
2002XTREME's Avatar
2002XTREME is an unknown quantity at this point
I rec had the same problem in my 2002 with a 4.3 it was the starter.. $160.00 for a brand new brand name starter for advanceauto and wala problem solved...mine bench tested fine also.
Old May 19, 2011 | 06:22 PM
Burnboy's Avatar
Anyone else?
Old May 20, 2011 | 06:44 AM
Pewter2002's Avatar
Pewter2002 is on a distinguished road
It might be your starter but do you have a good battery to try first? A good battery should have 12.5 volts at rest, 14.5 volts while the engine is running. Also, a battery cable can have internal corrosion that you can't see without stripping the outer insulation off. Are all connections tight? But try a good known battery first.
ynoth
Jan 8, 2010 01:28 AM
95blaz4x4
Oct 9, 2006 10:32 AM
fivemillerz
Jul 17, 2006 08:26 PM
dcjones
Jan 19, 2006 10:54 PM
danimalvt
Engine & Internal
Dec 20, 2005 08:32 PM
