amp placement
I was looking around in my 03 two door for just such a place yesterday. The best i came up with was behind the drivers seat. I would put one there, and build a little wooden box that i would cover in black carpet (like my truck) and i could just put that over it if i needed to, but i would leave it open unless i park somewhere shady, or i have somebody ride back there. The only thing is, i don't think you would be able to fold the seat down. This would be a hell of a spot for a number of reasons, the center console is right there, so i could probably run the wires right into it, and there are a few seatbelt mounts right there, in front and back of it making for a good ground spot.
ORIGINAL: Canadian88
I would make your own ground whenever possible, as opposed to using an existing bolt. Personally, I like to drill a hole into the metal, grind off the metal on both sides and insert a bolt through the metal of the vehicle. This way, you get a solid ground and a good place to ground all of your electronics, such as the headunit, amps, processors, etc.. to help eliminate the possibility of a ground loop. Just be sure that you protect the bolt under the vehicle as you don't want it to rust.
Hope this helps!!!
Hope this helps!!!
96jimmyslt4x4
Feb 24, 2011 07:15 AM
jerickso
Apr 20, 2006 11:05 PM
