One sub hitting harder
#21
#22
ok, wire the jumpers on the subs so that each is presenting a 4 ohm load and then wire the actual sub in parallel. Positive from sub to positive of other, negative to negative and back to box. there is your 2 ohm load.
OR, wire each sub parallel to present 2 1 ohm loads, then you wire in series which is probably easier. Positive from terminal to positive on one sub, negative from 1st sub to positive of second sub, negative of 2nd sub back to terminal of box and you're good.
#23
#24
Why are you running an amp that puts out 1000 rms with 8awg wire?
#25
i thought he meant he wired the subs with 8 gauge not the amp.
anyways... i agree, we need the setup pictures
#26
8 awg is WAY overkill if it's from the amp to the sub. But i have a feeling he's running 8 awg for power and ground...
#27
i would use 8 guage to my sub if i had some spare laying around. right now i have 12 gauge because its what i had. it also leaves room to grow
ussexplorer
13
06-02-2015 03:04 PM
96jimmyslt4x4
10-05-2011 04:16 PM
blazergirl15
07-09-2005 03:26 AM
