Strapping 2 1000w amps
ORIGINAL: jagblazer01
x2 on this...its just as easy to run an amp to each sub. strapping can get complicated especially if both amps are not set exact. Bad things happen lol.
ORIGINAL: bobditts
are you sure the amps are strapable? Not all amps are. they have to be specifically made to do that. Personally, I would just run one amp to each sub. 2000RMS is a bit on a stock charging system. I would definitely look into upgrading the alt.
ORIGINAL: oakleyg
I think you got that backwards, gain matching the amps when you run one amp to one sub is a little more difficult than strapping them. When you strap them the slave amp gets all the settings from the master amp so theres less tuning involved.
ORIGINAL: bobditts
i have 2 diamond audio tdx subs with 2 diamond d51200.1 ampsrunning along with a high amp... each 1200 is runninga sub... putting an extra battery in the back is a bad idea cuz that strains ur alt even more... when every1 says strap them that can b good and bad at the same time... ifu mess up onsomthin bye bye subs... if i were u i would just run each amp to each sub and bridgethem down as low as u possiably can... also run 1/0 gauge if u can afford it...u will notice alot of difference if u do that...
ORIGINAL: bobditts
either the amp is bridged or its not, there are no choices
ORIGINAL: PABlazer
i was talking about the subs bringing them down as low as u can
ORIGINAL: bobditts
post ***** much?
ORIGINAL: blazerbumpin
yeah its called strapping
ExplicitYourSelf
Dec 13, 2010 11:50 PM
