My small 96 Blazer build
Old Dec 12, 2015 | 04:37 AM
  #1541
Toocute350's Avatar
Toocute350 is on a distinguished road
I have a bigger alternator, big 3 and a optima yellow top battery to keep up with my electrical needs!
The (Optima) battery is a great battery.I had the (red)optima battery years ago.They are pricey,but well worth the investment.A regular battery isn`t made to be abused while climbing over rocks, drivng through 1-3 ft. of mud.The (Optima) battery is what you call a dry cell battery.It`s made to take the abuse while in the woods on a rainy day.
Old Dec 12, 2015 | 04:43 AM
  #1542
Toocute350's Avatar
Originally Posted by ACA1001
Wow, been reading through this thread, this is an awesome build. Still have much reading to do though. Love how the Blazer has come along though, gives me inspiration for my own 1998 GMC Jimmy. One question though, are there any legal issues with having big tires like that that extend out wider than the body of the vehicle? Or does that depend on the state one is in?
It`s illegal in any state, if and when you have a tire that pertrudes past the wheel well/front fender more than 1".
Old Dec 12, 2015 | 07:12 AM
  #1543
newguy's Avatar
mass. law Notwithstanding the provisions of this section, no passenger motor vehicle shall be operated on any way if such vehicle has the side wall or thread of any tire projecting outward beyond the outer portion of the fender or side body panel, unless such vehicle is equipped with four-wheel drive or is otherwise modified and intended for off-the-way use
Old Dec 12, 2015 | 08:44 AM
  #1544
ACA1001's Avatar
ACA1001 is on a distinguished road
That sounds like a carve-out though, as then basically anybody could claim their vehicle is for off-road use. I am assuming these laws are only for usage on public roads and not for off-road trails (so you could say tow a rig to a trail?).
Old Dec 12, 2015 | 08:49 AM
  #1545
ACA1001's Avatar
Sounds good
Old Dec 13, 2015 | 08:15 AM
  #1546
Smitty Smithsonite's Avatar
Very few places in MA to legally off-road, so I'd say yep - that's for the street.
They're not quite as harsh as they were 25 years ago when the whole lifted truck thing took off, though. The staties used to routinely sideline and tow (at your expense, of course) any vehicle they deemed "over the limit". Had a friend that got towed twice. That's if you made it through inspection ... which you wouldn't have, unless you did the lift just after the sticker was put on. Once a year you'd have to take the lift completely out and swap tires to stock, just to have a shred of legality in this bastion.
They don't call Massachusetts "The land of 1,000 laws" for nothing ...
Old Dec 17, 2015 | 07:35 AM
  #1547
Tajohns34's Avatar
IIRC in Pennsylvania your tires cannot protrude and further than the last row of tread past the fender. So I guess if you run slicks they can be as wide as you want. I really need to make a trek down to VA again and see the blazer.
Old Dec 17, 2015 | 03:39 PM
  #1548
WatchItExplode's Avatar
WatchItExplode is on a distinguished road
Technically, Optima is an AGM battery, not a dry cell
Old Dec 18, 2015 | 07:07 PM
  #1549
rexmburns's Avatar
Super Moderator
Well it's official I am officially on tons!! I pulled into the shop about 2:15 this afternoon and drove it out at 5:30. I ended up pulling the rotors off my 44 and swapping them to the 60 since my buddy still hasn't had time to cut the other ones. I've got all matching studs at all for wheels which is really nice. My tie rod ends are shot so I just put them on enough to move it out of the shop and I have some ruff stuff 3/4" heims ordered so I'll swap all that out when they get here. I've still got allot to do but I'm stoked to finally have a 60 up front. I also have to order a new u joint for my front shaft cause I learned yesterday that the yoke on the 60 is a 1350 yoke.
Back on its own weight got he first time
Back on the 40s
And outside to prove it moves lol!
It's crazy how much bigger things are on the 60 compared to the 44. Look at the difference in the hubs
Next week I'll work on getting all the small things buttoned up while I wait for my heims.
To do list:
Finish Steering
Alignment/center steering wheel
Install locking hubs
Grease King pins
Double check brakes
Double check u bolts
Mod trans cross member
Mod y pipe
Install drive shaft
Install hydro steering
Drive it!
Attached Thumbnails My small 96 Blazer build-f6fe63cc-2539-444a-acc2-d64c9859912e_zpsdyehhbyy.jpg   My small 96 Blazer build-f0b27f46-53f0-4cfe-9a7a-d1e3234c8545_zps4krgyfju.jpg   My small 96 Blazer build-944818d7-d359-405e-ae17-2d277163c4c9_zpsklwa4lpl.jpg   My small 96 Blazer build-5cc20c1b-70ff-41fb-a04d-1557cd43eb0f_zpslkiamtkw.jpg
Old Dec 19, 2015 | 08:17 AM
  #1550
Getting there! Those axles should last a lifetime.
